Front door locks
Mike Poole22/02/2022 11:26:18
3676 forum posts
82 photos
I worked with a chap who had an implant in his hand to operate his front door lock, electronic locks are increasingly popular as many hotels have embraced them. The RFID tags are very effective access control and even if a tag is lost or compromised it can simply be deleted to restore security. They could be issued to carers and the window of access programmed for their appointment times and days only. Center Parcs have installed a RFID system that controls accommodation access, swimming pool lockers and can be linked to a bank card for cashless payments to in pool refreshment facilities. The tag is contained in a wristband that can be worn in water. The company I worked for had a photographic ID card that contained a tag and gave out of hours access to the plant, vending machines and canteen checkouts also used the system. It also controlled access to restricted areas. Lost cards could be easily deleted and new ones created very quickly. One hotel I have used controls lift access from the lobby with your room card but once you have been admitted lift access is not controlled so if you lock your card in your room you can return to reception.
