Is it the brass or the die?
Howard Lewis | 10/08/2023 15:49:39 |
7227 forum posts 21 photos | FWIW I only buy HSS Taps or Dies from Tracy or Tap and Die Company. Problems? One Tracy Dies was marked on the back instead ofn trhe front , another cracked. Both replaced without demur. Tap and Die, again had one Die crack, replaced.FOC. I set Dies, wherever possible, using a commercial bolt or setscrew as a gauge, before use. or open up and use the intended nut as a gauge for subsequent cuts, if needed. Often cut under power, (Using the VFD "Jog" facility. or a Mandrel Handle for blind holes or shoulders ) dry for brass, lubricated for steel HTH Howard
