Bore Gauge
Ramon Wilson | 22/02/2020 20:37:18 |
![]() 1655 forum posts 617 photos | I would agree Neil that you can use a slip pile or a micrometer to set a two point gauge but I think you would agree to it's not the easiest way to establish a 'zero' for measuring a bore. For many years I worked 'in microns' on multi stage progression tool parts. The environment was not temperature controlled save ambient temperature - up one day down the next. It was just taken that everything we made was relevant to the dimension required - max tolerance was .01mm min was .002mm don't ever recall any temperature related problems with tooling as made over some fourteen years. BTW did you ever get those Oliver drawings I sent via Dean ? It would be nice to know Just had a look on Arc Euro Graham - set of three three point mics 11 to 20mm are £368 - far too much to justify I'm afraid but boy, I would like'em Regards - Tug Edited By Ramon Wilson on 22/02/2020 20:38:22 |
