Rod Neep | 08/05/2016 09:44:30 |
![]() 59 forum posts | Thanks for that Jason. The whole thing was fascinating breakfast reading. |
Tim Stevens | 09/05/2016 18:33:11 |
![]() 1779 forum posts 1 photos | The metal you show looks like 'black' steel as used for welding structures. This helps to explain the burrs you noted. I have found inclusions of slag in such material - visible strands about the size of a pencil lead. This is no problem for welders (who tend to cut with shears or angle grinders), but it can wear cutters quickly. You might get a better finish and longer tool life if you seek out 'free-cutting bright mild steel'. Cheers, Tim |
Rod Neep | 09/05/2016 18:45:03 |
![]() 59 forum posts | Lesson learned, Tim. Thanks. That's what I thought I had ordered, but as these pieces were to be just clamping plates I decided to just go ahead with them. Cheers Rod |
