2-6-0 Horwich Crab
Dave Wootton27/12/2019 11:55:30
505 forum posts
99 photos
Very nice job Stew, have been following your progress with interest, been building a 2 1/2" gauge Crab for a while, there's a picture in my album. on hold due to moving house and imminent redundancy and early retirement.
Hope to be able to get on with it soon, you have spurred me on to paint my (almost finished) tender, keep us posted with your further progress.
Keep up the good work.
Jeff Dayman27/12/2019 14:47:06
2356 forum posts
47 photos
Looking great Stewart! Thanks for the progress report.
Stewart Hart22/05/2020 07:54:57
674 forum posts
357 photos
Time for an update, this lock-down has certainly speeded things up:-
Chimney, Smoke box, door and saddle
Trimming smoke box to length
Smoke box saddle fabrication
Completed smoke box door
its begining to look like the finished loco now
Stew
old mart22/05/2020 16:43:29
4655 forum posts
304 photos
I've just read 50 Famous British Locomotives by Peter Herring and your crab is in there. I see that it is the angle of the cylinders that is responsible for the nickname. What ever would Stevenson's Rocket be called at that rate?
Greensands22/05/2020 17:33:35
449 forum posts
72 photos
Hi Stew - Your Crab is coming along very nicely and the build quality to say nothing of your rate of progressive is most impressive! I notice that the smokebox has been painted. Would you be able to give a brief account of what surface preparation was carried out, which primer have you used and the make an type of black paint, (presumably a heat resisting grade) and not least, your method of application i.e. brush, aerosol or spray gun.
Stewart Hart22/05/2020 18:26:59
674 forum posts
357 photos
Thanks for your comment old mart
Greensands the smoke box is not painted it’s made from welded seam mild steel I think it must have been hot rolled hence the black surface. For my other loco I used black engine paint from Halfords on smoke box and chimney just two coats. For the tender and rest of the loco the brass gets a coat of acid primer followed by two coats of precision paint followed by two coats of clear lacquer from hobby craft I use a wide soft artist brush again fresh hobby craft I can’t get on with spray cans. I try to do one face at a time keeping it horizontal to reduce the risk of runs it takes a long time doing it this way but it’s the only way I can avoid runs
Hope this helps
Stew
Edited By Stewart Hart on 22/05/2020 18:34:04
Greensands22/05/2020 20:19:01
449 forum posts
72 photos
Stew - Would you recommend putting a primer on a mild steel smokebox before painting with Halfords engine black and if so, would this be a standard red oxide as again sold by Halfords?
Stewart Hart22/05/2020 20:35:00
674 forum posts
357 photos
Hi
I think I used primer on my first loco it’s stood up to many steaming I do know I was very careful to get everything cleaned and oil free using a gunk type solvent and white spirit
Stew
