Member postings for David Parsons 3
Here is a list of all the postings David Parsons 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Vibration Ramping
18/04/2012 21:09:36
It wasn't the quill, It was clear to see that the endmill had moved from where I had originally set it.
I don't have enough experience to comment on the fit of the endmill in the collect, however, had it been loose when it was in my hand before attachement common sense would have told me something wasn't right.
Definitely a 12mm collet.
It can only be that the collect wasn't tight enough. I suppose by the low response to my question of vibration/bounce, we can rule this out. Back to the machine and a much closer inspection of the collect and drawbar.
Kind thanks for everyone's help.
Thread: Using a lathe
17/04/2012 19:29:56
As someone has already said, the Ian Bradley book is a must. It's a very easy read for the beginer and gives lots of useful information. It is highly recommended.
Good luck.
17/04/2012 19:11:21
I'm using an R8 collet in my Myford VME Mill.
I'm trying to reduce the thickness of some gauge plate, and then add numerous holes.
I have mounted the plate on two parallels, the gap bridged underneath is 150mm. I have been told that 15mm thick plate can bounce quite easily, however, I proceeded being that I need the gap underneath in order to drill my holes through the work.
As I was reducing the thickness over the area of the finished piece with a carbide center cutting 12mm endmill, going from side to side etc, I noticed the tool was making a progressively loud vibration noise. Closer inspection of the work revealed that the endmil had been slipping down the collect and thus been cutting a downward ramp into the work instead of a flat cut.
Questions.
Although I'm inexperienced at milling I'm fairly confidant the collet was tight enough, I mean you shouldn't have to get them so tight that they are close to striping threads on the draw bar do you ? So I'm guessing this was down to the work piece bouncing and thus grabbing the tool and pulling it into the work ?
Can bounce really do this ?
Also, in order to stop bounce should I have a third parallel bar in the middle, and then remove this to drill my holes at the end ?
Any help or advice would be much appreciated.
Many kind thanks.
David
Thread: Myford Lathe service
01/03/2012 11:10:36
I tried that email, but no response.
Anyone got a number for them ?
Thread: Lathe Leveling
22/02/2012 23:50:56
Jason,
I'm following manufacturers instructions of NOT using the tailstock. Only fine cuts are used.
To clarify to everyone, I'm not using the top slide, and I'm using a very slow power feed off the leadscrew.
Many thanks.
22/02/2012 23:44:08
Martin,
It was under the cabinet. I guess this might have been where I was going wrong with the test ?
22/02/2012 23:20:42
Would I be right in saying that if the headstock is out of alignement then it needs rotating clockwise if looking from above ?
Many kind thanks.
22/02/2012 22:43:30
I got a problem with my Myford Super 7.
Everytime I try to make a rod it ends up having a bigger diameter on the free end.
I've gone right back to basics. I've purchased a Moore and Wright engineers level and got the bed pretty damn level. I followed the manufacturers instructions, turning a one inch bar over a length of five inches, without using the tailstock. I took very fine final cuts, making sure the cut looked and sounded uniform across the entire length. Over a 4 inch distance the results are that the free end away from the jaws are 0.1 mm larger diameter than the chuck end.
Following the instructions, I jacked up the front foot of the tailstock end. I repeatdly did this until the rear foot was off the ground, but i am still out by 0.1mm everytime I conduct the test.
Completely at a loss....
Any suggestions?
Many thanks.
David
Edited By David Parsons 3 on 22/02/2012 22:44:54
Thread: Whistling Cutter
15/02/2012 18:49:37
Thanks for the responses.
I would find it hard to imagine that the cutter is now blunt, it's seen very little use, and I certainly didn't persist with that whistling cut.
It wasn't on the end of the plate and so therefore can only be the depth of cut, unless of course something funny happened to the entire plate.
I will try a 2.5mm cut and see if this resolves the problem. Failing that a carbide cutter will be purchased.
Question though...
What is the physics behind a whistling cut? Is it the endmill rubbing against the work without taking an actual cut?
Many kind thanks indeed.
15/02/2012 17:00:45
I'm trying to mill some gauge plate steel on my VME Myford mill. I'm using a fairly new 10mm HSS endmill, but everytime I apply even the slighest sideways movement to the table the cutter starts whistling.
What's the problem? Is the cutter blunt already?
The cut is 5mm deep, I'm using plenty of coolant, everything's locked down properly. It only takes the slightest of pressure on the table and the noise just seems to get louder and louder until I let off.
Many thanks.
Thread: 3 Phase Tripping
15/02/2012 16:24:26
Blimey this is a good forum. Loads of advice and very much appreciated.
My electrician said it is more than likely an earth problem related to the garage,
He came round, fiddled with the wires, bypassed the extension I was using and now everything has been working sweet.
If anyone reading this is having similar problems, as can be seen in the lists, check for a good earth, even if it means running an extension from a neighbour. Also, make sure the fuse box is rigged up for the power you're using etc.
many kind thanks to all.
David
04/02/2012 16:39:59
Hi Les,
No, it was at a completely different address.
However, it is still plugged into a 13 amp socket just the same.
I know RCD's can 'trip' just from a spike. Could this be the problem? Too much power too quickly?
David
04/02/2012 15:33:25
Hi Les,
I mean the main fuse box in my house. Trip switches I call them. It pops the main one, so everything I own turns off. I've just checked, and it has RCD written on it.
The problem happens when I switch the inverter on. I plug the whole machine into the socket on the wall, turn the socket on, and POP !
Moisture shouldn't be a factor. The machine has been moved recently, but has always been in a good quality garage that is dry, although often very cold.
Many kind thanks.
David
04/02/2012 15:16:34
Hi JD,
Thanks for that advice, I've checked inside the box and everything still looks new, certainly no mice or spiders etc.
I've also checked the plugs for signs of damage, and they all look fine.
To clarify. It's not when I turn the motor on, it happens when I flick the switch on the wall, which is a 13 amp plug. This plug works fine with other appliances.
Bless Myford, they always used quality items and components. The gubbins inside the 3 phase box seem to be from a reputable company, so I will try contacting them Monday morning.
I was wondering more if this was a known fault, or if there is a reset button I should be aware of etc etc etc.
Many kind thanks.
David
Edited By David Parsons 3 on 04/02/2012 15:18:02
04/02/2012 14:48:34
Hello,
I have the large Myford VME Mill with 3 phase converter. I haven't used the machine for a couple of years, and now everytime I switch it on it pops the main circuit breaker to my whole house. I must have tried it 4 times on the trot, and everytime it pops the main switch.
Any suggestions people ?
Many kind thanks.
