Here is a list of all the postings Four stroke Fred has made in our forums. Click on a thread name to jump to the thread.
Thread: Mc Donald Model tractor |
05/10/2022 10:53:38 |
Fred. |
26/09/2022 23:35:50 |
This weeks efforts saw the gas cylinder in place and the gas jet set and working as it should do. Two problems did raise their heads and need to be addressed. The first was the oil in the the oil box siphons down to the engine when left over night. I think this can be resolved by the addition of two small springs to hold down the ball check valves in the pump body and not rely on gravity or the weight of the steel balls to form a seal. I have discovered that my electric razor has springs of just the right size and shape. Just call it recycling! I will need to drill and tap a drain hole in the engine crankcase to allow excess oil to be drained out. Fred. |
19/09/2022 09:03:19 |
The photo shows the gas tank and burner in position. The head of the burner and the filler in the tank came from a small pencil type gas torch with the tank being made from brass and copper. I do have to set the length of the flame but have made the stand so the this can be adjusted to suit. All the cheese head screws on the model have now been replaced with hex heads ( as near to scale as possible). The oil pump has had its stroke reduced by 30% and the injector set at 20degrees before top dead centre. All gaskets have now been made and fitted but I do still have to check and test the cooling system. I read in a motorcycle magazine about a fellow who had just restored a bike and was not sure if he should kick into life or sit, admire and enjoy the product of all that labour for a while! That’s how I feel about the Mc Donald but as I do need to see and hear it run ( if it will) before I start the painting process I will try giving it a whirl in the not to distant future! Fred. |
11/09/2022 09:50:57 |
Roger that is part of the next weeks test program but I am prepared to remake or adjust parts if required. Fred. |
11/09/2022 05:38:41 |
04/09/2022 08:59:29 |
04/09/2022 08:56:58 |
I never thought I would be able to say that there are only two more parts to make plus any I have to remake. The photo above shows the two stage reed valve induction unit. These reeds were originally designed for small motorbikes where at low speed only the the two small petals open but as revs rise the secondary kick in ( the larger part). The steel protruding plate prevents the reeds from contacting the flywheels. The second photo shows the chain drive from the engine to the gearbox. Commercial chain is used and it does not require a tensioner - more by luck than calculation. I did have to remove a link and make use of a half link as a joiner. Having careful separated the link that had to be taken out I was ready for the next step but no I accidentally picked up the link I had just taken out and fitted it to the chain. That’s how to waste time with out really trying! I still have to make and fit a chain guard and also connect the clutch lever to the clutch. Fred. |
01/09/2022 04:21:51 |
01/09/2022 04:18:30 |
Thanks for the comments Martin and Diogenes it’s good to receive feed back. I started this as log of the tractor construction to keep as a record for myself but it just grew and grew! It has been useful as there have been times when I have had to repeat a process and I have been able to check back in the log to see how I did a process or set up the first time round. I think it’s also good for other model engineers to see what is normally hidden on a model like this and perhaps get ideas or may be even inspiration. I remember my first visit to the MEX back in the early 1960s and how that inspired me and set a standard that some day I may achieve. A model such as this is a challenge and the problem solving stimulates the brain and at my age you need to keep that active! You asked what will be the next model and the answer is that I do have several model to finish. One is a 67cc V8 and the second is a working scale model of a 250cc. single cylinder racing motor cycle. I have the frame already made but at the time I had neither the ability or equipment to complete the model - like wise the V8 has already had the parts cast and partly machined and it about time it was finished. Also there is a 5” gauge Terrier class loco and a 3 1/2” gauge Tich that needs attention but as my interest in steam has diminished they will have to wait. I will just have to live longer or find a 28 hour days! The shed / workshop is a wonderful place to be and when I am in there any aches and pains just disappear. Having a hobby like this has given me new circle friends who share the trials and tribulations of the journey and the learning curve continues to grow. I have reached the stage with this model where it appears to be nearly finished but some of the small tasks and problems do take time to resolve. Structurally the end is in sight but then there is the interesting stage of experimentation with all the settings and hopefully it will go. There is no guarantee that “Go” will happen as there is no instruction book but it doesn’t stop one from trying. Perhaps at some time in the future I may bring the finished model to a MEX but that depends on many factors some beyond my control. If it does happen I look forward to meeting you all face to face. The photo shows the tractor at a local club day display last Saturday. Fred.
30/08/2022 08:42:22 |
30/08/2022 08:21:45 |
The list of jobs continues to reduce. This weeks work included the connecting up of all the water inlets and outlet pipes but the main effort went into machining and fitting the cast iron liner. Machining the bore was a long task as the final cuts were very small and lathe speed very slow ( about 20 minutes per pass )Having machined it to the required size both inside and out I was ready to press the liner into the cylinder. Guide lines were marked to line up the ports with the port holes in the liner. All went well with the fit being just right and in line with the top of the cylinder but a check revealed that the liner had rotated slightly as it went down the bore - oh bother! Next job was to make an extractor jig to remove the said liner. Double checks we’re made and this time all was well with all ports in the liner matching up with the ports in the casting. The piston complete with rings can now move up and down the cylinder. The next major job is working on the cylinder head. I also have to make and fit the rod that connects the clutch lever to the clutch and make and fit the chain drive to the gearbox. Photo to follow. Fred.
14/08/2022 09:43:25 |
Fred. |
11/08/2022 03:50:09 |
Fred. |
31/07/2022 05:37:18 |
Today more 3D printing and casting. These are the saddle’s for the fuel tank and when cleaned up will be bolted to the top of the engine. |
29/07/2022 08:50:56 |
Fred.
25/07/2022 09:11:15 |
25/07/2022 09:10:38 |
This weekends workshop time was spent on the injector set up ( but not the timing). These small parts take longer than expected to both make and then set up and there seems very little to show for the hours it has taken, but it’s all to do with the vision of the end product. Each division on the throttle “gate” is 5 degrees and equates to half a mm of movement on the injector plunger via all the levers. If this amount of movement is excessive there is provision for the leverage to be changed but experimenting will determine if that is required.The crankshaft has yet to have the flywheel keyway cut but as this keyway may also drive the eccentric for the injector I have held off the process. Fred.
19/07/2022 07:32:34 |
11/07/2022 10:27:13 |
Fred |
11/07/2022 10:09:37 |
Fred.
