Here is a list of all the postings Pete Titan has made in our forums. Click on a thread name to jump to the thread.
Thread: 4.5 inch (4 1/2) scale Allchin Royal Chester Castings? |
15/01/2014 10:44:28 |
I shall do that, thanks very much indeed. |
Thread: Open thoughts |
15/01/2014 10:41:47 |
Yeah, I'd agree with O.P. My father works at a clay quarry and model engineering is his hobby. He has made some beautiful engines. Then, having said that, with ref to qualifications, he decided to go to open university to read a maths degree because he found his methods of machine set up used maths... I grew up around old oil engines and steam models and with my feet planted at the foot of the lathe from an early age, began building and honing my 'engineering ability'. I chose to do a degree in engineering after my A levels, which was intended to help me secure a good engineering position - However, being a particularly firey individual I found taking orders from half wits in jobs I'd secured hard to do, so set up my own business in a field that I have interest and experience in. (A vehicle workshop) The thing I always think about engineering is that 'Engineering' means different things to different people. For instance, the workshops I went to after uni were all CAD/CAM orientated. Generally you simply pressed go on a machine or put a fresh bit of stock in the chuck, or on the table. If you had no actual practical ability, you would find it hard to come home from work and set about making something (My colleagues always admired engines I took in to show them but couldn't conceive how it could possibly be done with manual machines and files without CAD. But they would still consider themselves 'skilled engineers' Whereas I considered the quiet and usually forgotten chaps that were designing the parts, working out tolerances, UTS' centrifugal forces, failure probability with F.O.S and loading etc to give the CAD people something to draw the true talents. I myself found university slightly bizarre as there was very little practical (mainly due to health and safety) and all you were required to do was prove you could make something. In our case a silly little 3 legged bearing puller, which ironically I never made because I took in a couple of my engines and they decided it was a waste of resources. Instead I turned out some rear wheel rims for a traction engine I was finishing for a friend. Now I really do love maths, and physics and all things mathematically derived, but I do remember a moment at about 3am one morning when I was working on a piece of coursework due in the same day. (also knowing as last minute stupidity) I was writing out some polynomial division as part of a proof that 22/7 is greater than pi and I remember thinking to myself, I know what pi equals, why I am proving what pi DOESN'T equal when I could be making something constructive!! To me, broadly, engineering is the series of solutions (machining / design calculations etc) that turn an idea into a practical item. But then I build models and I consider that engineering so who knows!! I do largely agree though that daytime job versus hobby are often worlds apart. I once knew a concrete worker who would go home a build clocks...how such dumpy fingers could even pick up half the components of it was beyond me! Anyway, at present I and talking on the model engineering site when I really should be working! Kind regards, Pete. |
15/01/2014 09:49:23 |
Good morning all. I'm on a quest to find a supplier of 4 1/2 inch Allchin castings. I have spoken to Paul Wainwright and I understand he is not really doing much with the models anymore, since the full sized engines are taking up the majority of his time. Does anybody know of any other suppliers of castings for this beautiful engine (John Rex only lists 3" castings) and if not, does anyone know a rough pricing for cast iron casting per weight for me to make a couple patterns and find a foundry? (I have emailed my local [Bridport] foundry but no response after a month) Incidentally I only really need the following if anyone knows of anyone looking to shift old stock: Cylinder block Flywheel Compensating centre trunk guide Brake drum Rear wheel hubs Many thanks, Pete |
Thread: Hi, and Suffolk Dredging Tractor |
26/12/2011 20:35:16 |
Posted by Flywheel on 25/12/2011 10:33:53:
Hi Pete,
if it is of any use to you I have for disposal volume 146 of ME [1980] which includes the 11 part series by John Haining on the Suffolk Dredging Tractor?
Merry Christmas
Peter
Good evening to you. And seasons greetings! Thank you very much for your offer. I'd be interested in having a flick through the articles to see if any more detail is given. Please message me more information, or a number to arrange something if you are willing. At the end of the day, with bits that don't make sense, (like this rear suspension arrangement) after a few sketches in the notebook the problem is either resolved, or completely avoided by redesign!
I've been warned this could be a fun one, but as far as I'm concerned the full-sized prototypes were all fairly unique and variable so why shouldn't our models follow in that spirit! Besides, a little bit of retrospective design never hurt anyone and personalises things nicely! In many cases a slight tweak here and there can make for a much more durable / usable / authentic engine anyway.
A quote from my late grandfather was "Who's f?!?!?! engine is it anyway?!?!" which very much complements my attitude to things!
Enjoy the festivities!
Pete,
24/12/2011 18:40:21 |
Posted by Brian Dickinson on 24/12/2011 04:34:24:
In the model engineer series it gives a companies name for the gear set, i am not sure if they are still around?? But the gears were well made. If you have trouble try SH Muffets who have an extensive range of gears. http://www.muffettgears.co.uk/
I bet they won't come cheap! I was looking at making my own - I know it generally take me around 2minutes a tooth the cut, rewind, index, and start next tooth. Drawn out process but It's not a race and I get an amazing amount of satisfaction from gear making (unless I miscalculate the indexing amount and end up with a really wide tooth at the end!)
By the fact you're thinking of building another, I'm assuming it was a great little engine when finished?
Merry Christmas,
Pete
24/12/2011 18:32:55 |
John, thanks for the reply - only after I clicked send did I realise that 1 - (2 x 0.125) was 3/4 and would hence fit in the internals of the box section.
Thanks for clearing up my question regarding support at 2nd shaft. I can't see the slotted link at the rear and assume in missing something with regards to how the rear of the subframes / springs attach. (I can picture it in my head, but logic is suggesting that the rear most end of the rear spring will need the eye reducing in width.)
As for 4 / 5 leaves - The drawing shows 3leaves for the rear springs and 4for the front (?)
Sounds like you're a fair way along with your model. I'm gonna get the chassis started on mine just after the new work bench is finished (Christmas Project!)
What is troubling you with the boiler? My boiler is about 70 % complete. Made in copper instead of steel. 10gauge being my choice. (since we don't need to equate for wastage!) It's a fairly lumpy kettle, but with careful forethought and kawool and brick hearth setup on the workmate it's going together quite nicely. All done outside, so won't be doing much to the boiler now until the weather settles.
My Thoughts at the moment are whether the make the boiler ends flat as per drawings (but obviously flanged for solder area) or whether to try and make them dished as per gas bottle ends. Train of thought being if I make them dished I wouldn't need the stays.
I'm quite looking forward to getting on with the main tractor, but can see many little alterations to the drawings - several things look to be sloppy. Like the circular die blocks - easy to make, but I can see the single point contact in the links giving an annoying clicking through wear after relatively short run time.
Anyway, I should be in the workshop, cutting metal, not at the computer!
Merry Christmas
Pete |
19/12/2011 21:49:40 |
Hello
This is my first post to this group, so thought I'd firstly introduce myself.
My name is Pete, and I'm a 25year old Model and experimental Engineer from Kingsteignton in Devon. I earned a degree in Beng Mechanical Engineering at uni, mainly inspired by my hobby of model engineering which follows in the bloodstream from my father and his father etc! I have been engineering with intent since around 1997, with Edgar T Westbury's Unicorn as my first project (I was 11).
I've built a few engines to date, including:
Unicorn (mill engine), Fitzfizgig (hot air), Tich, several Stuarts - a couple James coombes, 3 Reals, 10V's, 10H's, S50's and a Clayton Steam Lorry in 2" including all the extras - brakes, steering mods boiler mods and a gearbox (which make a days steaming pulling me and a couple others around no problem - and I'm just shy of 17stone!
Anyway, my main purpose for posting is that I'm looking to my next project, which will be a Suffolk dredging tractor as I have to admit I fall into the category of 'love' rather than hate. I have the drawings and a fair whack of the material for it.
My question goes to anyone who has built one - The drawings aren't exactly crystal clear!
what's the arrangement with the rear springs and axleboxes and subframes? Are the subframes hinged only at rear most end (via the subframe support bars) and supported from collapsing by springs against axleboxes? Are the springs just floating on the axleboxes? Also are the springs reduced in thickness from 3/4" at the eye end to go in rear spring hangers alongside the subframe support bars (looks like they'd be reduced to about 1/2inch) and at the other (flat) end reduced to about 1/2 inch to slide into the slot in the other spring hangers?
Also the dotted outline of the engine columns on sheet 3 show the front end of the subframes supported by the 2nd shaft and then the columns fixed again cross member '2'. Surely this would render the whole subframe solid and therefore render the springs as dummies?
Or am I missing something?
I apologise about the essay of a post, but thought I would kill two birds with one stone (introduce and ask a question all in one post)
I look forward to any comments and hope as a member I can offer advise to others.
Kind regards, Pete
