Member postings for Martin Dilly
Here is a list of all the postings Martin Dilly has made in our forums. Click on a thread name to jump to the thread.
Thread: Hobbymat Lathe - Play on Cross-slide
01/08/2011 18:04:57
I've found that my Hobbymat lathe has about 0.15mm play on the cross-slide, such that when I push and pull on the dial (at right angles to the lathe bed) there is visible and audible movement relative to the saddle. I've adjusted the backlash to no effect.
I suspect wear either on the threaded rod controlling the cross-slide movement or else in the female thread in the saddle casting. Does anyone have any suggestions for a cure please?
Thread: Hobbymat - Play on Cross-slide
01/08/2011 18:03:25
I suspect wear either on the threaded rod controlling the cross-slide movement or else in the female thread in the saddle casting. Does anyone have any suggestions for a cure please? I'll post this on Beginner's Questions as well, just in case.
