Member postings for swood1
Here is a list of all the postings swood1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Small lathe dial suppliers
11/05/2021 21:11:41
Yes I could,
Looking at the design today, I believe I can accomodate a 34mm diameter dial.
I shall have a look at your suggestions. Thanks
Steven
11/05/2021 08:20:36
Posted by Journeyman on 10/05/2021 14:36:30:
Whilst the 1mm pitch is a good idea I doubt you would get 100 divisions on a dial only 20mm dia. Each division would be 0.6mm (approx) apart a bit too close, you might manage 50 divisions though which is a nice round number.
John,
I think I am going to take your advice above and make my own.
Thanks all
Steve
10/05/2021 20:51:16
There are some useful responses here, thanks.
I didnt think of the mircometer dial, just wondering if I could buy some 2nd hand ones and modify them.
Steve
10/05/2021 14:29:34
Thanks John,
Your response gives me options. The cross slide I have been designing and making myself so it's not specific to a manufacturer but I like your idea of marking a faceplate for the divisions.
Out of interest I was looking at a cross slide leadscrew with a 1mm pitch, Would it make more sense to have 100 divisions on the cross slide dial?
Steven
10/05/2021 13:50:52
Hi all,
Does anyone have a source for small diameter dials for a small watchmakers lathe?
OD - approx 20mm
ID - approx 10mm
scale - 50 divisions.
Steven
Steven
Thread: BCA m3 jig borer Linear scales
18/03/2021 15:18:10
Hi Michael,
What are the benefits to the rotary encoder? Is it more compact?
Steven
18/03/2021 13:40:00
The more I think about it the more I realise that micrometer depth stop is actually a really good idea Phil.
Good solution..
18/03/2021 13:32:39
Thanks everyone for this. I like Phil's solution as dont really see a benefit of adding DRO to vertical for the work required.
Phil,can I ask where did you get your copmact Sino Linear scales from? Im going to go for the most accurate ones as may as well utilise the accuracy of this machine.
regards
Steven
17/03/2021 16:25:36
Hi all,
I'm looking to add linear scales to my BCA mk3 jig borer. Looking at it I believe I can fit both an X and a Y linear scale but a Z would be too messy/complicated. Does anyone on here have experience with adding such a scale to this machine?
Kind regards
Steven
Thread: Myford S7 long bed
03/02/2020 09:58:11
Hi all,
Thanks everyone for your feedback on this. I shall try to arrange to view the lathe and measure said wear areas. I should also use some common sense and measure my current S7 bed for wear too
I need to also check my workshop for space. Hard sometimes to know if you can fit a machine in until you have it in front of you, in the workshop.
Steve
02/02/2020 19:27:39
It would be a tight squeeze in my workshop to be honest, but it just about fit. The serial number would mean it was built in the early 1980's. My current S7 is dated around 1969, mine is in very good condition but I should really go and see this other lathe I think. The seller wants £1,200, do you think that would be a good deal on a good condition S7 from the 1980's?
Steven
01/02/2020 23:10:07
Hi Baz,
To be honest you are spot on with your questions. I only occasionally do long turning. The machine doesnt come with screw cutting gearbox but it is a very good price. But just been reading about the machine on Tony's website, you are correct I didnt realise it was so much longer.
Steve
01/02/2020 21:36:38
Hi all,
I currently have a Myford S7 without power cross feed or screw cutting gearbox. However I have the opportunity to upgrade to a Myford S7 Long bed with power cross feed for the price I believe I should get for my current S7.
Firstly, how much bigger is the long bed and more importantly how much heavier? I got my original S7 with cabinet in the back of a Honda Civic hatchback (with a little care). I now have access to an estate car so hopefully the S7 long bed would fit in the back with cabinet. But, what does the general community think of the S7 Long bed? I dont hear it mentioned much, is it an upgrade?
Steve
Thread: Milling machine & Shaper query
29/01/2020 16:49:49
Hi Peter,
Surely it's not just the depth of cut but also the width of the cut? Or am I missing something? I don't know as obviously I do not have a shaper.....
Steve
28/01/2020 22:42:07
It sounds like people like their shaper machines....
Out of interest what is the sort of footprint required for an 8" shaper like a Boxford and how heavy are they?
Steven
28/01/2020 09:55:32
Some interesting feedback here, I think the general consensus is that if you can afford it and you have a use and room for it then go for it. The idea of just sharpening a bit of HSS and using this for cutting metal sounds ideal to me..
Now I need to measure my garage workshop.... I am thinking I could fit it in the end by the garage door but I was trying to avoid blocking this entrance up (although I hardly use it).
We shall see.
Steve
Thread: New member from Worcestershire
27/01/2020 21:01:15
Hi all,
I am a new member from Worcestershire. I repair clocks and watches as part of my job I also work in automotive industry.
Basically I have quite a complete workshop, however you may have recently seen my post reference looking at purchasing a shaper machine.
Hope all are well
Steven
Edited By Steven Woodward on 27/01/2020 21:02:16
27/01/2020 16:05:59
Hi all,
I have always fancied owning a shaper machine; I like the simplicity of the machine and have a few projects that I could see would suit it better than my Mill. But I already have a small mill, I was wondering do some of you out there actually have both machines and more importantly do you actually use them?
Would the shaper be a waste of already lacking space...
Kind Regards
Steven
Thread: New to Lathes, Which Chuck?
12/10/2018 17:25:22
Hi Teery,
It's a Lorch plain turning lathe. I have the same one, I use mine for clock repair amongst other things. As well as a countershaft please dont start it up without adding any oil into the holes on the top of the two towers on the headstock. I have a couple of cups on the top of mine where I pour in oil to lubricate it. It looks like you dont have a backgear system on yours (I dont have one either).
I have lots of attachments for mine, most stuff I have adapted from other lathes to fit it.
I tried to attach some photos but cant quite work out how to do it.
Enjoy
Steve
