Here is a list of all the postings John Farmer 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Transporting 5 inch live steam loco |
11/10/2021 17:32:38 |
I have a 150kg lifting table bought new on Ebay about 5 years ago quite a bit cheaper than M/c Mart but still good quality. Ideal for moving w/shop machinery too. I am also hoping to buy a 5" loco soon but my concern us how to hold it in place in the car (estate car in my case). What do others do - photos would be useful. John |
Thread: Allchin trunk stay |
25/05/2019 15:32:29 |
I am working towards construction of the boiler for a 1.5" Allchin. Looking ahead I have been studying the text and drawings and wanted to clarify something. The drawings (6 & 9) refer to a stay for supporting the end of the trunk guide which extends back from the cylinder. There is a reinforcing pad inside the boiler, which I have located, and then there is a curved angle bracket riveted above this pad on the outside of the boiler. There is then a short stay from this bracket to a lug under the trunk guide. It is the curved angle bracket I am concerned with since, if it is riveted to the boiler it must be fitted before assembly of the boiler, but I cannot find any dimensions of the bracket or any measurements showing its location. Can anyone advise on these points please? Thanks, John |
Thread: Brazing hearth - Extraction |
17/01/2019 23:36:26 |
My thanks to everyone with the ideas so far, much food for thought. Just to clarify, the flamefast I have acquired is just the basic brazing unit, i,e. a stand with a fireproof work surface and surround - no gas connections and no overhead extraction unit. The hole in the wall vents to the side of the garage over a path to a side door at the front of the house, thus I wouldn't want any external ducting or blower there. Further thoughts welcome. |
16/01/2019 14:40:44 |
I am about to embark on my first boiler and I am setting up a brazing hearth. My workshop is a double garage, integral to the house. I have obtained a used Flamefast hearth which will be sited against an outside wall of the workshop. There is already a 6" dia hole through the wall above the hearth. In order to ensure maximum safety I plan to have some sort of hood over the hearth with an extract fan exhausting through the wall. |
Thread: My mag is falling apart |
02/11/2017 19:22:39 |
It worked - I'm in. Sorry for interrupting your flow.... |
02/11/2017 19:13:37 |
It appears I need to "make a small number of forum posts" before I can respond to a classified ad (about old ME mags), despite having been registered with this forum for a good many years, and posted a couple of posts in 2014. So this is just one of my "small number".
Thread: Thread cutting problem |
01/04/2014 20:35:09 |
Thanks for all the advice so far, all much appreciated. For old Al, yes I am already using the 60 degree topslide method. For Howard, I did think about turning down 10mm round, but shied away at the difficulty of then milling it down to 2mm (how do you hold the last bit!. So, I will be trying either the solder or the Loctite method which seem the easiest to try. It will be the end of the week before I am next in the workshop. I will try to remember to report back. John |
01/04/2014 17:49:17 |
I am trying to replicate a small part from an antique mechanism, circa 1900. The part is made from 10mm x 2mm mild steel bar and one end is narrowed to 5mm for about 1cm length. This section, now 5mm x 2mm, has a 5mm thread formed on its narrow edges and I am having great difficulty replicating this section. I am trying to "screw-cut" in the normal way in a Myford, using a 60deg HSS tool and very slow cutting speed, and a depth of cut of 0.0025 inches at a time. I get so far but then the steel just twists and bends. The cutter is sharp. Any ideas on improving the method, or is there a completely different process for doing such a job? I have spoiled 4 pieces so far. John |
