Here is a list of all the postings Wolfie has made in our forums. Click on a thread name to jump to the thread.
Thread: Fuel Tap material |
20/12/2015 11:00:58 |
I need to make a small part for a fuel tap. The original part is brass, I don't happen to have any of the right size. Can I make the part in steel?? Or is there a reason why its brass? It will get petrol on it. |
Thread: Italian Motorcycles. |
20/12/2015 10:44:05 |
Sorted the wrap |
Thread: Fuel tap leak |
28/11/2015 20:14:17 |
Yeah an internet search told me about the corks, got some new ones on order! Just occurred to me I have some bits of Delrin lying around, I wonder if they would make a good seal?? Edited By Wolfie on 28/11/2015 20:17:32 |
28/11/2015 12:25:10 |
My fuel tap has a small but steady drip when closed. Do I need to worry about this?? |
Thread: Hello I'm Skelly |
22/11/2015 23:10:01 |
Hi and welcome, there's a motorcycle thread in the vehicle restoration section. Post pics! |
Thread: Hi I am Richard from Glasgow |
22/11/2015 23:08:12 |
Hi and welcome |
Thread: BSW/BSF vs BSC |
21/11/2015 18:35:36 |
I have a spares list for the bike, it obviously lists the parts and part numbers, what it doesn't do is give any dimensions |
21/11/2015 16:01:37 |
OK I have made a start and the first thread I've come across is a stud under the saddle. It just holds a bracket on but I'd like to run a die down the stud as its rusty. The thread is 1/4" across (well actually 240 thou) and its 26tpi according to my thread gauge. How can I tell whether its 1/4" BSF or 1/4" BSC. I know ones 55 deg and ones 60 deg but how do I tell. They are slightly recessed so I cant look side on with the thread gauge |
Thread: Whats this tool? |
21/11/2015 15:56:30 |
I finally moved my workshop and one of the things I unearthed is this.
Errr what is it? |
Thread: Thrust washers |
06/11/2015 10:14:47 |
OK whats a thrust washer? I know its supposed to stop lateral movement of a shaft, but frankly it looks like any other washer to me, what makes it different? Can I just turn a new one out of a bit of steel or does it have to be summat special?? |
02/11/2015 23:01:46 |
Cheers, already got the Ratio books on order |
01/11/2015 23:11:46 |
I'm assuming that on a Beezer I'll find BSC screw threads as opposed to BSW/BSF. My question is WHERE I'm likely to find them? I mean are they used across the whole bike or just in certain areas? |
Thread: Motorcycle General Discussion |
01/11/2015 14:27:54 |
Posted by thaiguzzi on 01/11/2015 07:28:38:
Edited By thaiguzzi on 01/11/2015 07:35:36
31/10/2015 15:36:41 |
When I'm not fixing a BSA....
31/10/2015 15:29:44 |
Haha Oh dear never noticed that
Posted by John Stevenson on 30/10/2015 20:27:19: Posted by Wolfie on 30/10/2015 19:14:26:
Motorcycles might be the subject for model engineers of the future! Have added a heading for Motorcycle restoration so any bike talk can go in there .
Hang on. You have started a fresh thread in the fresh thread that was stared for motorcycle topics
Thread: BSA C15 project |
30/10/2015 19:27:30 |
Here it is!
Thread: BSA C15 upgrade to 12v electrics |
30/10/2015 19:16:12 |
I should mention that its a positive earth too although I can't see that making any difference |
30/10/2015 19:14:26 |
Motorcycles might be the subject for model engineers of the future! Have added a heading for Motorcycle restoration so any bike talk can go in there |
30/10/2015 19:10:24 |
Right then I'll set the ball rolling. I note with interest the comments about upgrading to 12v electrics. Is it really that easy?? Just join the two sets of wires? You don't have to upgrade the alternator or the coils or anything, they can all handle 12v? I do have the Haynes manual with a wiring diagram for the Star, but I'm not sure its complete as I don't see an earth from the points nor a spark plug! |
Thread: Motorcycle Restoration |
30/10/2015 19:06:13 |
Done, see bottom of this section! I'll add my queries on the C15 electrics there Edited By Wolfie on 30/10/2015 19:06:45 |
