Member postings for Tony Jones 3
Here is a list of all the postings Tony Jones 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: 3MT quill
19/08/2010 14:48:32
Hi Keith,
                   Yes it is 3MT, I have searched on the web for a manual, found one but they want over £100 for it, seems a lot to me.
Thanks,
                     Tony
19/08/2010 11:08:52
Thanks,
                 I have made a couple of drawbars with different threads and use a dead blow/copper hammer  to nock  them free, the problem I have is , take for instance , a 3MT fly cutter ! it will not fit in the quill because the MT taper does not locate before the tool head hits the end of the quill,  the reason being the  flats between the taper and the tool head are not there on a lot of the tooling I have. also there are no slots in my quill to allow a taper drift.
Thanks
19/08/2010 09:17:02
Hi, Thanks,
                         I did not discribe it well, ! the quill takes 3MT tooling and has a drawbar , the 3MT tooling must have flats at the end of the taper that fits in the quill to stop it from turning as well as the drawbar, my mill is a FRITZ WERNER 3.230, it is a big heavy machine and works well, I do not have a manual or anything for it.
Thanks
18/08/2010 16:16:08
Hi all,
           I have a old milling machine with a 3MT quill, the problem is I cannot  use a lot of my tooling in it as the 3MT tools must have a flat section that fits into the quill, is there a conversion that will allow me to use an ordinary 3MT and also pass the drawbar through.
Thanks.
