Here is a list of all the postings Steve Rowe 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Loss of power |
11/11/2016 18:43:04 |
11/11/2016 18:41:54 |
Hi All PROBLEM SOLVED........ I don't have a mains test lamp but do have a multi meter. I attempted to test the NVR switch and was not able to pick up any Voltage on any terminals. I then searched for a point to pick up V and looked at the re fuse holder. Bingo. The rear of the fuse holder was loose and I found this had been the cause of the arching. I now just need to acquire a new fuse holder. THANKS to all of your help. Best Regards Steve Rowe |
10/11/2016 10:50:58 |
Hi Rik Chester DB8VS Lathe. It has variable speed control. Thanks Steve |
10/11/2016 09:31:16 |
Hi Neil. Thanks for your reply. The chuck did turn and the display lit when I pressed the green button but now I have nothing, no turn and no light. Hard to explain as when the problem started the display panel lit and chuck turned only momentary when I held the button in, I also heard interference on the radio as if something was arching. Now I have nothing at all working, including the display. Thanks for you time. Best Regards Steve |
09/11/2016 13:33:41 |
My lathe stuttered to a stop and the display light went out. I instinctively pressed the green button on the stop/start switch. The display momentarily lit and the chuck turned until I released the green button. I also noticed an interference noise on my radio as I held in the green button. I repeated with the same result. I tried for a third time and everything was dead. No display light etc. I am no electrician but jumped to the conclusion that the stop/start switch had failed. I ordered and fitted a new stop/start switch but this made no difference. I also changed the machine fuse, 13 amp plug fuse and checked for power to the 13 amp socket. I have no idea what is causing my loss of power to both the display and lathe motor. Any help or suggestions would be greatly appreciated. Best Regards Steve Rowe, North Staffs, UK
