Member postings for Alexander Edblad
Here is a list of all the postings Alexander Edblad has made in our forums. Click on a thread name to jump to the thread.
Thread: LBSC Invicta frame plate question
08/07/2013 12:48:37
Well, I think the best thing to do is start off machining the cylinders complete with steamchests, and then make the valve linkages to line up properly with the valve spindles.
What I' m worriyng for more is how much/little side play is needed.
07/07/2013 23:13:08
Fizzy,
Thanks for pointing that out. I believe that you mean the triangle shaped rocker arm? Here´s a link to a picture which shows that part. **LINK**
Please correct me if I´m wrong. I don't have the plans at hand this late hour. By the way, do you work with castings or stock material?
Alex
06/07/2013 21:11:52
Thanks Phil. Now I should be good to go. Unfortunately I don' t have the building article so just relying on the plans.
06/07/2013 19:16:26
Hi all,
I'm building the frame plates for the 3.5" Invicta. The plans seem to be missing a dimension which sets the angle of the cylinders. There is a motion center line that starts from the rear main wheels, but no indication of the angle of that line.
Is the angle not that critical? There are a few other measurements lacking as well so it makes scribing out the lines rather difficult.
I do hope you understand what I mean.
Thanks,
Alex
Thread: Cutting fluid when reaming
15/08/2010 22:45:15
Hi all
What type of cutting fluid do you recommend for reaming? I remember using denatured alcohol in school (for machining of course) but I'm not sure that was the correct fluid to use.
Alex
Thread: How to drill a square hole?
21/07/2010 13:04:49
Seriously  now.
The buffer beams for my Invicta should have 1/8" cutouts for the coupling hook. What is the easiest way to do this? I guess I could drill four or so small holes and then file to get it square. Are there other options?
Thanks
Alex
