Member postings for Stephen Wessel
Here is a list of all the postings Stephen Wessel has made in our forums. Click on a thread name to jump to the thread.
Thread: Armstrong - Siddeley Lynx 7 Cylinder Radial Engine.
21/11/2013 17:55:31
I have just spotted this post several months later. I do intend to have the drawings available but not until the engine is finished and running which may be sometime in 2014. I would point out that there are a number of very intricate aluminium castings required for which I have all the tooling mostly in the form of silicone rubber patterns and moulds. The actual casting is best done by specialist foundries.
Before finishing the drawings I would like to have some idea of how much interest, if any, there might be out there in reproducing this fine historic engine in 1/3. I might be able to assist with the production of waxes but do have a full time job to see to as well!
All enquiries are welcome and I should be pleased to discuss this project with anyone seriously considering it.
Stephen Wessel
Thread: Ignition coils for small engines
22/07/2010 19:20:51
Hi Dixie and John.
Thanks for the link to Minimag. Julian there was very helpful and sent me a new sensor which is now set up and ready to go. I shall remember your valuable tip John about keeping the HT well away. It could indeed have been a bit close and may have caused the trouble. Engine is now ready for start up so we shall see.
Steve
10/07/2010 15:23:37
Hi. I'm new to this site. Re electronic ignition for small engines I have been using various modules on my 9 cyl rotary with a Hall effect switch. Recently I've been having start up trouble as follows: engine starts as normal,runs up to speed then cuts completely, all lasting about 3 seconds. You can repeat this ad nauseum but engine will never keep going. Frustrating as it has worked beautifully up to recently, flying a Sopwith Pup very realistically.
Lack of fuel was an obvious possibility but long since ruled out. Timing & plugs are  correct. I found today that the Hall sensor now doesn't work at all. So my questions are:
a) what happens to them to cause failure?
b) might gradual failure cause the symptoms observed?
c) how do I choose a new one bearing in mind my knowledge of electronics is almost zero?
My current module is a Zenoah running off 4.8V
Any help much appreciated. Thanks
Steve
