Here is a list of all the postings Vincent Cutajar has made in our forums. Click on a thread name to jump to the thread.
Thread: Bending Mild Steel Flat bar |
07/03/2011 18:26:01 |
I was thinking of holding one side in the vice and heating the bend area only with a torch. |
07/03/2011 17:53:49 |
Jason & Tony
Thanks for the reply. I suspected that I need to heat it. I am assuming red hot should be enough. I will experiment with a similar piece of scrap flat bar and see how it goes. I can't afford to get it wrong on the original piece as too much work has already been done on it.
Vince |
07/03/2011 17:17:10 |
Hi everybody
I have a mild steel flat bar which is 18.5mm x 9.5mm and about 18inches long. I need to give it a small bend roughly in the middle. Can I try to fix it in a vice and bend it cold or do I need to heat the bend area?
Thanks in advance
Vince |
