Member postings for PETER KING
Here is a list of all the postings PETER KING has made in our forums. Click on a thread name to jump to the thread.
Thread: Vertical Spindle Surface Grinder
07/11/2019 23:03:57
does anyone know where in ME an article on building a Vertical Spindle surface Grinder is?
Peter King
Thread: Help need with Drill jig
12/09/2017 04:52:42
Does anyone have a 'size 2 Reliance Drill Grinding Jig' ? I want to make a replica - I have both No 1 & No 3. but I need to know what its dimensions are - all 3 were to the same proportions. just the dimensions of vee drill tray is enough.
Thread: Drill bit sharpener
16/01/2014 02:41:36
Hi, Some months back the old "Reliance" drill grinding jigs were mentioned, I have both No1 and No3 (which as mentioned is vast) I am looking for a No2. for small drills - under 12mm - I use a machine similar to a 'Drill Doctor' but it is an all-metal job with precision ground collets. its called a GS1 and is probably Chinese. this does normal and split point grinds to various angles from 90 degree to about 120+. the drill doctor I had was plastic and notable for lack of accuracy. PETER KING
