Member postings for George Tilley
Here is a list of all the postings George Tilley has made in our forums. Click on a thread name to jump to the thread.
Thread: Sieg X1L Mill Failed
19/03/2020 20:11:08
Hi Guys,
Thanks for all the advice. Unfortunately I am not am electronics person and have no knowledge of testing a PCB, likewise no idea what a mosfet is or what it looks like. Spoke to Ian at Arc, who was quite interested in my problem and he reckons it is either the motor or board, favourite the board, and highly unlikely to be the speed controller. When I was checking the motor brushes one of the retainer grub screws shattered so I have to make a new one of those, looks like an M12 x 1 thread. I have a piece of 12mm delrin and am waiting for the die to arrive. Once I have made the new grub screw I will see how to attach the wires to the motor from the 12v battery. If the motor proves sound I will order a speed controller first, as it is the cheapest possibility, and if that fails I will order a new board. Hopefully I will be up and running after all that. I will also look for someone who fixes PCBs to have my original fixed to act as a spare. Incidentally I live in Oldham.
Cheers,
George
13/03/2020 10:23:18
Thanks Steve will do.
12/03/2020 23:14:26
Hi Guys,
Any advice on what might have failed on my Sieg X1L mill? Finished working last night and everything was fine, went to carry on this morning and although the power light came on the speed controller did nothing. Looking at the different component costs the speed controller is £10 and both the motor and control board in the region of £100. Is it likely to be the speed controller or is it a common problem and it is always some other assembly/component? The motor brushes look fine.
Thanks in anticipation,
George
Thread: Centre of a cylinder casting.
07/03/2016 11:15:28
Hi Bob,
Thanks for your offer I will definitely take you up on that. I have
not joined a club yet but I will when I start construction. I have a choice
of 3 near me Sale, Urmston and Rochdale. At the moment I am constructing
a gauge 1 4F to get some experience on an easier project as I am new to
this. I am looking forward to silver soldering next once the drier
and warmer weather arrives as I will be doing that in the garden.
Thanks again,
George
04/03/2016 12:27:51
Hi DMB, I expect to have plenty of offcuts when I make the boiler, I have not silver soldered anything yet although my wife bought me the Sievert gear for Christmas. Making the boiler will be VERY interesting!!!!
03/03/2016 10:35:12
Thanks for the advice Bob. Once I get started I will take you up on your offer of advice.
01/03/2016 17:19:37
Thanks Lambton, JasonB & John for your answers. As John has written one of the biggest problems for beginners. I just could not see how to do it but at least I now know that it cannot be done perfectly but more of find the best solution you can based on the factors explained above and work from there.
Cheers,
George
01/03/2016 13:38:26
Thanks Neil. The card Template sounds a good idea.
01/03/2016 12:06:23
Hi Guys,
I am looking at building a 3 1/2 inch gauge Fowler 4F. I have bought the drawings from Reeves. One thing that confuses me is how to find the centre of the bores of the locomotive cylinder casting. Reading the articles that people have written it says plug the casting end with a piece of wood and mark out the centre. As the castings are rough how do I measure and mark out the correct position for each bore? Where do I measure from?
Cheers,
George
Thread: How do you use indexable cutting tools.
13/09/2010 13:40:17
Hi Andrew,
Thanks for your comments.
 I will get some decent inserts and have another go. Do inserts cut at the top or bottom edge as this will alter the tool height setting?
The C3 is not too rigid but works fine on HSS or brazed tip tooling so I was hopeful that indexable would work as well.
Cheers,
George
13/09/2010 13:11:37
Hi Peter,
Should it be at the same height setting as HSS tools?
Tools are brand new but sold as economy.
George
13/09/2010 12:31:50
Hi Guys,
I have a C3 lathe from Machinemart and I am very happy with it for the work I want to do. HSS and carbide brazed tip tools work very well but I cannot cut at all with indexable tools. The tool just skips along the outside of the workpiece leaving barely a mark. This happens on BMS, brass and aluminium. Is there a different cutting technique required for indexable or ??.
 My tools were not expensive but I would expect them to do something.
Thanks,
George
Thread: Thread up to a shoulder.
15/03/2010 09:02:20
Thanks for all your replies guys. Think I will counterbore the hole on this occasion and see how it goes.
Thanks again,
George
11/03/2010 12:14:55
Hi,
I am very new to practical engineering and would like some help please. I am currently trying to build a gauge 1 project 4F. Many of the drawings show components which are fully threaded right up to a shoulder. My dies leave an unthreaded section of about 1/16" next to the shoulder and I don't fancy cutting this type of thread using the lathe.
My question is can you cut a thread to a shoulder if so how or do you pack the uncut section with a washer or such like?
Thanks,
George
