Member postings for Peter Ridgway
Here is a list of all the postings Peter Ridgway has made in our forums. Click on a thread name to jump to the thread.
Thread: Denford CNC milling
09/03/2010 15:07:09
I have a Denford Easimill 3 and have had no problems. I still use the original controller and software supplied by Denford. (recommend their users forum! every helpful) The most useful thing I did before buying the machine, was to attend evening classes City & Guilds Part Programming. This helped greatly with confidence using the machine and diagnosing my own programming. If you can afford the space I'd go for an ex industrial machine, the interfaces are usually easier and more powerful, and it save retro fitting for Mach 3 control.
Thread: Boxford AUD Belt Renewal
09/03/2010 14:53:26
Hi,
I have an Boxford AUD, and as the previous people have mentioned I use Brammer belt. How ever fitting can be a little diffucult, removing the top cover and the rear belt guard will ease the threading of the belt (three screws on the back guard, four on the top). If you haven't taped the new belt to the old one to pull the new belt through.
Additionally if you fit the recommended 4.25ft of belt. You may find it easier to make the joint with the belt off the lower pulley. Then to fit the belt with out damage, slacken the four grub screws (two each end), remove the three allen cap screws holding the end of the counter shaft to the cabinet (outer end) and remove then casting. The counter shaft will now lift just enough to pull the belt over. Simple no straining. Hope it helps and happy turning.
