Member postings for Geoff Byman
Here is a list of all the postings Geoff Byman has made in our forums. Click on a thread name to jump to the thread.
Thread: Replacing Warco WM16 spindle bearings
22/05/2020 10:12:50
Hello Mike,
Thanks for the info. I'll take a look. As an old (slightly updated dinosaur engineer) I never think to look on the net for info like this.
Must update my research methods! 8-))
GeoffB
21/05/2020 11:44:04
Hello All.
Been a while since I asked for advice on this as health issues had stopped all really physical work - workshops and the like. However, now back to some form of fitness, I've finally stripped the spindle.
Firstly, the videos on the Grizzly G0704 machines helped as most of the replacement was similar although, now that I've stripped the spindle, the bearing sizes are different on the Warco to the Grizzly. The bearings are NSK HR 32005 XJ.
Also, in the videos, no mention is made of the large bearings in the head, that the internally splined, gears run in. Whilst I understand that the quill is tightly locked in its uppermost position at all times for CNC work, do these bearings play a big part in true running of the spindle or is it just the spindle bearings?
Having stripped the taper roller bearings out of the spindle and closely examined the outer races, there are some curious darker "patches" of wear(?) diametrically opposite, each of about 1/5th of the circumference of the middle of the race. I assume that this is probably the cause of the chatter? Anyone have any ideas? Where would I get advice on this?
Any help would be greatly appreciated.
Many thanks,
GeoffB
26/06/2019 14:36:18
Hello Hopper. Thanks for the reply. I had always thought that taper rollers were the best for the job - having worked in the racing industry we used mainly taper rollers wherever possible. The ones in the video are angular ball race bearings - these, they said would not get as hot as the taper roller type, although a few comments suggested that this is not really an option - however, these comments come from "armchair" critics and not from actual experience, so where does that leave us?
My machine, as I said earlier, does get reasonably hot but not unbearably so - maximum I have ever measured has been 40-50 C but that was after a long 4 hours machining run.
RMA - As regards the original bearings - well, being a Chinese origin machine, I would suspect that the price constraint would dictate cheaper bearings, so I have looked into replacing with SKF/Timken (we used these in motor racing quite a lot!) but to be honest, how high a quality do you go for with a machine of this build? Do you know of anyone who is suitably versed in bearing technology to give me a reliable guidance?
GeoffB
25/06/2019 23:14:23
Many thanks for the info on bearing preload. You didn't mention whether you thought it OK to go for the taper bearings as per the original or the upgraded bearings mentioned in the videos, as according to some comments, there seems to be conflicting opinions as to which is best. Any idea where I can obtain reliable info to help decide which bearings to go for?
Regarding warm up, being CNC, I ALWAYS run the spindle up for at least 15-20 minutes before using the machine to do work - never run it cold - gradually running up the speeds from 2000 to 4000 over the first four/five minutes and then hold it at 4000 on computer read out and watch for the RPM counter on the head (actual spindle speed) to creep up to the correct speed as it warms up. When it has come up to temperature (readings matching), then I run the machine.
GeoffB
24/06/2019 12:47:01
Hello all.
Well thank you all for the quick response to the question. I knew that there was something holding the head - had looked initially for a grub screw or something, but couldn't find one. With this info from Alan Lloyd (thanks) I had another look and then removed a bolt and nut that had been fitted to the side of the head to hold a bracket for an airline attachment - looked in the hole and lo and behold, there was the grub!!
Thanks George, I do have the parts list from Warco that came with the machine, but, although I did search, this doesn't list the errant grub screw.
Hadn't known that the Grizly G0704 was the same machine so wasn't searching for the right videos. Many thanks to Bandersnatch for pointing me in the right direction. Just having to go to a darkened room to get over the shakes!!
Having watched the video and read the comments posted about the bearing upgrade - what are your thoughts on the bearing change, as my mill is doing the sort of RPM that is shown in the video. The head does get hot - 40- 50 C - after 1/2 hour or so running - being CNC, some jobs will be as long as 60 minutes plus running at 4000 RPM. Having said that, the machine has done a few years work as it is on these bearings. Also looking into the high seed grease equivalent of the one mentioned in the video (Kluber NBU15) with Omega Isoflex SSP.
Is there anything else - apart from the bearings and slide way clearance - that could be causing the recent onset of judder? Has been cutting beautifully for a long time then suddenly developed this judder.
GeoffB
22/06/2019 16:32:35
Hello All,
New to MEW. I have a Warco WM16 mill that has been upgraded to CNC milling - quite successfully. However, it has just developed a judder and has been tracked down to the spindle bearings. I need to remove the milling head to replace the bearings and although I have removed all bolts/nuts the head will rotate but not come off the vertical slide block. Is it held in by any spring rings or such - does it just prise off?
GeoffB
Thread: Denford CNC milling
01/03/2010 17:01:26
Hi,
Just seen this post - looking for anything on CNC machines - and can say that the Mach3 software is very good and is licenced for private use. There are a few machines around that are quite good and use proper ballscrew nuts and good driver boards, but there are a good few that do not use these and don't do the job properly.
Whilst returning this post, are there any users out there that have the warco cnc miller?
GeoffB
