Member postings for Adrian Dixon
Here is a list of all the postings Adrian Dixon has made in our forums. Click on a thread name to jump to the thread.
Thread: Tools
06/07/2012 22:03:19
As stated above my understanding was to open existing holes (note ref. to casting 'cored hole' ). They reputedly give a more accurate and better finished hole than a standard drill and are a half way house to a reamer, but definately no substitute for one. I have, I think, one in the workshop and have never used it!
Adrian
Thread: Myford Saddle Stop - Hemingway
11/01/2012 21:09:11
(Contd. from previous posting - text was too long for one!)
I was lazy when it came to the thread indicator attachment stud and did not make the bolt come stud as per drawing but used a length of commercial ¼” BSF studding I had in stock with the original nut to secure the indicator. Then came the next problem, the stud did not line up with the tapped hole in the 3/8” bar, this despite careful marking for the hole in the block as recommended in the instructions. The cause soon became apparent and was no reflection on my machining nor the design. Without the thread indicator fitted all was perfect, the faces on the indicator were not square to the bore nor parallel to each other, hence when the nut was tightened the stud deflected off centre! To be fair to Myford we are trying to do something that was never intended, hence this out of square was previously of no importance. I turned up a stub in the chuck that was a push fit in the bolt hole in the indicator and skimmed the faces true and all was well.
The final word of warning…..all then fitted and worked well but if you have a power cross-feed machine be aware that the inner end of the shaft that carries the push – pull knob for engaging and disengaging the feed can foul the T bar at the inner end of travel with possibly severe consequences. There is ‘free’ movement at the inner end of the travel of the shaft after the drive is disengaged so I removed the knob and both circlips (one in front and one behind the knob) and fitted a 1/16” thick washer behind the second circlip which prevents the shaft travelling far enough in to foul the T strip. Another option may be to chamfer the ends of the T on the front face so the shaft will ride out and thus not cause a jam up. Your choice.
I’m sorry if this is long winded, but it is all fairly simple really and may help someone in the future. At the end of the day we are trying to shoe horn stuff into places that was never intended, hence maybe only fair to expect some issues?
Adrian
11/01/2012 21:07:10
In the absence of any further responses and now having completed the saddle stop I am able to offer the following information that may benefit others in the future(?). This applies to the installation for my long bed Super 7 with power cross-feed of 1980 vintage and may differ for other machines……….certainly my earlier pre power x-feed machine does vary slightly. There is very limited clearance for the saddle / apron assembly to pass with the T strip fitted due to the proximity of the saddle plate above, the rack pinion shaft below and the apron to the front. Before starting it is necessary to remove the cast alloy leadscrew guard and the blackened sheet steel piece behind it as these will foul the T strip. Once the T strip is fitted the sheet item can be reduced by about 1/16” on its inner edge to clear and a small corner (maybe 1/8” x 1/8” ) cut from the bolting flange of the guard. This does mean the assertion that ‘no modification to your lathe is necessary’ is not strictly true!
The T strip that attaches over the rack was machined from 5 x 12mm BMS strip in lieu of the supplied ¼ x ½” and the width was reduced from the stated 0.455” to approx 0.430”.
The 3/8” was maintained but the 1/8” thicknesses were reduced to approx 2.5mm each – although I erred on making the thickness of the top of the T slightly under and preferring to leave a shade more meat on the lips on the cast iron block.
The holes for securing to the lathe were offset towards the top edge of the strip, thus lowering the strip, by drilling about 12 thou off centre – without this the strip fouled the plate that holds the saddle down on the lathe bed. Note that due to the reduced thickness of the strip you cannot use 2BA cap screws as there is no room for metal under the head! My solution was to countersink and substitute 2BA x ¾” long socket head countersunk screws. As my machine is a long bed I made the T strip about 14” long and span 5 rack screws rather than 3 as per drawing – but note that the pitch of the screws is 3.300” on my machines – not 3.5” as stated on the drawing, though to be fair they do state to use the rack as a drill jig. I didn’t, just relying on the feed screws on my D/W for spacing and all was ok.
The position of the hole, in the CI block, for the brass clamp pads for the tee needs to be relative to the ‘T slot’ not the edge of the block.
The suggested woodruff cutter was no longer suitable due to the size changes and I opted to make my own cutter from 5/16” dia silver steel with a slot across the end and a small scrap of carbide brazed in and ground up – looks a bit like a boring tool. For security I threaded the holding end and used in the autolock chuck and basically flycut the undercuts one side at a time.
Despite taking care positioning the hole for the brass clamp pads for locking the 3/8” dia. bar the centres fell too close and the 2BA cap screw would not fit. The simple expedient was to locally turn the threads off. assemble the pads and screw to the block and then slide the bar in place. Take care – you have been warned!
(Continued in next posting).
Edited By Adrian Dixon on 11/01/2012 21:11:36
Edited By Adrian Dixon on 11/01/2012 21:11:59
13/12/2011 21:49:51
About twelve months ago I purchased a Myford Saddle Stop kit but on closer examination I realised there were issues with clearance for the 'T' bar that attaches in front of the rack. I enquired with Kirk at Hemingway and he did concede that he had heard of some problems, but believed they were only slight and that most were okay. I put the kit to one side.
Looking at it afresh I removed the leadscrew guard and then slacked one of the rack securing screws and backed out until it fouled the passage of the saddle over it. On the drawing the strip (and as supplied) is 1/4", however the maximum protrusion on the screw before fouling was about 0.232".
I then made a bobbin to fit the screw and of the same profile as the 'T' bar - i.e. 0.455" and 3/8" dia and with the 3/8" dia at 1/8" wide but the 0.455" dia reduced to give an overall thickness as 0.232"
On trial with this fitted the saddle would not pass as the plate that holds the front of the saddle down on the bed (Drg. Ref. KA7 - Part No. A9185) fouled the bobbin. I then reduced the bobbin diameter of 0.455" in stages until it would just clear and by then the diameter was 0.410" which is only 17-1/2 thou a side larger than the 3/8".
The lathe in question is a long bed S7 of 1980 vintage with power x-feed. I also have an earlier long bed S7 (pre power X-feed) and whilst I haven't examined as closely it does suffer the same problem.
Has anyone else made on of these kits and had the same problem?
It is livable with, nut the sizes are getting very neat. I did wonder about dovetailing rather than the 'T' section. Any thoughts?
Adrian
Thread: Dore Westbury Milling Machine
29/06/2011 22:33:07
Thanks for the responses. Yes it is 1/4" to transmit 1/3HP if I recall correctly. The existing belt is to most intents 'unbreakable' and one thought is to fit a jockey pulley to lose some length, but it would have to be supported off the bottom plate of the belt guard (an alloy casting) and would still potentially leave a problem in future when (if?) the belt ultimately fails.
I am currently using 6mm green belt bought at Harrogate last year, I think it is Swiss made. It runs in semi-circular grooved pulleys but the weak point seems to be the heat welded join, though I have managed to get a satisfactory result that has lasted several months now providing I don't try and take more than a light cut. It is a light machine but is capable of more than I dare subject the belt too.
The hollow belt with fasteners is an option but will the join cause noise and vibration? The smallest pulleys are quite small, maybe 1.5" - leather with fasteners is not preferred for the same reason.
I have seen it stated that the original belts were by a firm called Dawsons and that they no longer have the moulds. Re-machining to suit Poly-V belt (say only 3 wide) may be an option. Anybody tried that route?
Adrian
27/06/2011 22:25:28
I am having problems with the drive belt on a MkII D/W (i.e. with belt guard). The supplied round fabric reinforced belt is a shade too long (possibly stratched slightly over time) and I cannot get sufficient tension before the motor pulleys move too far back and foul the guard.
I am currenlty using 6mm green round belting but it is limited how much tension / loading the welded joint will take before it fails - I know I've done it! I have reduced the tension to the point that the joint survives but this limits the cut before slippage occurs (and the motor then gradually gets a covering of green dust off the belt!).
Does anyone have a solution, preferably know a supplier of a shorter 1/4" dia round fabric type belt?
Adrian
