Member postings for Eastleighite
Here is a list of all the postings Eastleighite has made in our forums. Click on a thread name to jump to the thread.
Thread: Boiler making hearth
18/05/2010 06:49:55
Why do you need a hearth, to you intend using parafine blowlamps for heat?.
Thread: Bending steel tube
13/02/2010 19:58:03
Use a plumbers bender with a 22mm former.
Cut 6in. pieces of 22mm copper tube in half - 'lengthwise',
(enough to pack out the former and slide) .
Anneal the steel tube. in way of bend,  insert 15mm. bending
spring and away you go.
Edited By David Clark 1 on 22/02/2010 15:39:23
Thread: Brass Shell Case
20/01/2010 07:33:48
I could do the job for nout, if you bring it round, at 76, i could show you nippers a thing or two about metal work, the last place that i was at, the boss came up to me,  to tell me that - 'R/R bristol', had just been on the blower, to say how pleased they were with the job that i had done. nuf said.
19/01/2010 19:45:08
Now come on you chaps, do your bit for the green lobby and turn off those lathes. Run a line around it with your height gauge, grab a pair of 'Gilbow' tin snips and in a spiral fashion,(mind your hands as the flash rolls off) , gently work your way gradualy to your line.     Ten minute job,  giving more time for the  -   'Yorkshire Tea brew'  by gum lads
Thread: Yarrow 3 drum boiler
03/01/2010 16:08:48
Hi ChrisH,
I would imagine that the Yarrow Boiler (see pics) that I put together some years back, is a little bit bigger than the one that you have in mind.  The customer, (a retired sea captain) was putting it in a flat bottomed Punt, together with a 'Stuart Swan' engine.  The steam drum is 5" dia. - water drums 3 1/2" dia. and it has- 144 x 7/16" tubes + 2 down -comers of  1/2" dia.  Owing to space, Fuller details plus hints& tips can be supplied if needed.  There are no drawings (to my knowledge) as it was a one off job.
Best of luck
Alf.
03/01/2010 15:44:46
Posted by ChrisH on 02/01/2010 14:00:34:
Have there been an articles in ME on constructing a 3 Drum Yarrow Boiler?
If so, what were the issue number or numbers please?  I presume back copies will still be available.  And also if so, where the articles in detail or just 'superficial'?
If not in ME, does anyone know where else such an article may have been published for the model engineer?
I am a subscriber to MEW not ME, hence  the queries.
ChrisH
