Here is a list of all the postings Simon Collier has made in our forums. Click on a thread name to jump to the thread.
Thread: vacuum braked passenger cars |
23/03/2014 22:25:54 |
We run a 5" gauge railway with vacuum braked trains. The locos pull up to 7 passenger cars plus guard's van, weighing up to 2 tonne, and the steepest grade is 1:60. On a busy running day, we give over 3000 rides in an afternoon. The braking system gives very little trouble. The engines' ejectors are used to apply the brakes, whereas ideally, the vacuum would keep the brakes off, for fail-safe operation, but this is how the system has evolved and it does work very well. http://www.slsls.asn.au/
Thread: Welding/brazing tips.. Propane vs Acetylene |
12/03/2014 07:41:43 |
The propane heating tip I mentioned above is exactly that: a cutting nozzle except without the central oxygen cutting hole. I had thought about simply using the cutting tips and securing the cutting handle somehow to prevent accidents, but in the end, ordered the special heating tip. As you found, it is a very different beast to the puny brazing tips. |
11/03/2014 05:26:08 |
Why not file one of the tips flush to remove the recess and see what difference it makes? I bought an oxy/propane set but found the #8 and 15 tips that came with it were not up to much, so I bought a heating tip for oxy/propane which puts out much more heat. However, it only fits on the cutting attachment, making it awkward. So then I bought a big acetylene tip, #32, and counter-drilled the end to make the recess for propane, but I have not tried it on a job yet. I have no idea why propane requires the recess but would be interested to find out. |
Thread: firebox crown height above centerline |
05/02/2010 06:06:23 |
Thanks for the reply. I do, in fact, have the book, but I was wondering if builders in the modern era, i.e., now, have strong opinions about these things based on experience. Martin Evans' statements are often very general and I doubt that he was infallible anyway, despite his vast contribution to the hobby. Mine will be 3/16 heigher I think. I will be using rod crown stays, not girder stays and I wish to avoid a thinner wrapper because of the greater number of stays required (AMBSC code- I'm in Australia). I suppose the essential question is: what is more important, more tubes or low crown height? Another possible disadvantage of a low crown is that it leaves a greater area above, unsupported on the backhead and firebox tubeplate, possibly requiring more longutidinal stays. |
04/02/2010 21:58:39 |
I am preparing to make a Springbok boiler using 10 gauge copper but in order to fit the tubes specified in the design by Martin Evans, 18 1/2" tubes and 4 7/8" flues, the crown height has grown 1/4" in height and has become flat-topped rather than curved. That would leave 2" space between the crown and the barrel (6"). The boiler is a parallel, round top, narrow firebox type. Because of the shape of the tube nest, in order to reduce the crown height significantly, I would have to leave out 6 tubes, leaving only 12. What do people think about crown height? I have read the thread on tube number with interest, as obviously, the two are interrelated. |
