Member postings for Thomas Chapman
Here is a list of all the postings Thomas Chapman has made in our forums. Click on a thread name to jump to the thread.
Thread: CNC Vertical Milling Machine
29/07/2013 10:43:46
Hi John,
I've got a few pointers that might be of help based on my experience using a similar sized machine to the one you are proposing, its a Sieg KX3 CNC which i've been using for the last 5 years. So if i had a wish list for your mill:
1) Spindle speed - the lack of rigidity for a small benchtop mill means that 'big' cutters, and when i think of 'big' this is anything larger than about 8mm in my case, gives rise to lots of vibration and poor finish. To compensate for the lack of rigidity, increase the spindle speed to as high as practicle for the bearings planned and use smaller cutters , <6mm. These small carbide mills can deal with huge surface speeds and have been a game changer for me. Increasing the KX3 to 6500RPM has enabled some useful removal rates with a 6mm 3 flute high angle cutter in 6061 Al with feeds of 600mm/minute and 4mm depth. At this speed and these cutters there is virtually no vibration and excellent finish. I would aim for 10,000 RPM if you can, using a poly V belt drive and VFD, you'll need plenty of HP for this, 2HP would be good starting assumption. There are numerous websites which have online apps to calculate the HP needed for cutters, materials and feedrates. If you want to do engraving, which is something that i found myself want to do quite often, for letering on panels, aim for 20,000 or a separate engraving spindle.
2) Rigidity - A rigid as is feasable!. Polymer concrete would be an ideal base, it adds 'dead' mass which helps with natural vibration. My father used to design machine tools and these used polymer concrete for super accurate, low vibration machines.
3) Accuracy - Most jobs are making parts that would be a pain or impossible to make by manual milling, or your making a lot of them. I'm not going to use it to bore holes expecting a bearing fit, so for me accuracy has not been something that has mattered as much as i originally thought, i get better than 0.05mm on all axis and this has been adequate, using rolled ballscrews and normal nuts (not the double ones).
4) Axis speed - i get about 2000mm/min max, which is already too frightening. so unless the machine is going to be used for production i would say this would be a good number to aim for. Microsteppers are quite adequate for this.
5) Y axis travel - Most manual mills dont seem to have much travel in the Y direction, probably because parts are often moved between operations. But for CNC you'r trying to do all or as much of the machining in one go with tool changes, so i would go for as much as you can. The KX3 has <150mm, which i guess came from the fact that it was an adapted manual mill, and this has been limiting , 250 mm would have covered almost anything.
Cheers
Tom Chapman
