Here is a list of all the postings Gordon Smith 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Computer Bewilderment |
03/09/2021 19:06:40 |
On some motherboards use of a M2 ssd disables some of the Sata channels. |
Thread: Any views on using Fairy Liquid in a concrete mix |
24/05/2021 18:27:10 |
Back in the 1960's we used Daz.
Thread: Hydrogen home heating |
18/05/2021 18:53:58 |
Look up Avogardro's number.
Thread: Windows for the scrap bin? |
18/03/2021 16:20:06 |
What you need is cloning software. I use Acronis to back up all personal files and system. Changed from hard drive to M2 NVME SSD with no problems.
Thread: Stuart victoria |
07/02/2021 13:50:40 |
Just seen your drawing and noticed piston rod 3/32 in shorter than my drawing! |
07/02/2021 13:43:35 |
My drawing number is 90071. The base casting changed when the twin set up was introduced? |
07/02/2021 13:05:50 |
This gets more confusing as there are 2 editions of the book on building the Victoria with different dimensions. Also my drawings from the kit I bought in early 1980s quote 6 5/32 in centres; the drawing is dated 13/4/76. |
07/02/2021 11:48:45 |
Just watched Keith Appleton's video where he uses 6 5/32 inch centres for the con rod and says these dimensions are in an errata paper from Stuarts. Unfortunately he has not got to the assembly stage yet to check the fits. |
07/02/2021 08:17:45 |
Maybe nothing but from the photos the main bearing is not centralised on the pad. Seem to remember the bearing casting was changed at some time. How about contacting Keith Appleton as he has You Tube series on building this engine? |
06/02/2021 22:04:50 |
In the Victoria book the dimensions are as Jason quoted for the Princess Royal. |
Thread: Aloris MXA QCTP for Super 7 lathe ? Maybe Myford brand QCTP ? |
24/05/2020 19:30:44 |
Steve Jordan did some YT videos on getting rid of the topslide and using a larger Aloris style QCTP. |
Thread: Model Engineering website DVD |
19/12/2019 18:59:42 |
DOH! I didn't scroll down far enough. Thanks. Gordon
19/12/2019 17:56:33 |
How do you read the DVD's of archived material from Model Engineering Website? I can't see any html files in file explorer. Gordon |
Thread: new computer |
03/11/2019 16:03:39 |
Just built my own computer. 3hrs work and works well. See Cary Holtzmann on Y tube for build examples.
Thread: Engineers blue alternatives |
19/07/2019 14:44:33 |
Doug The Prussian blue etching ink I got is manufactured by Cranfield and is oil based but washable with water. If you look at Tom Lipton's site on You tube he discusses the use of these type of spotting media. Gordon |
16/07/2019 17:51:24 |
I got my roller and water based colour from Amazon. Gordon |
Thread: Bookpress 5tpi Square thread help please! |
22/06/2019 08:59:26 |
Why not lay it flat and use the lathe?
Thread: Myfirst Myford Super 7 Mk1 Lathe - accessory identification |
28/08/2018 17:23:12 |
Go to Halfords and get a bottle of ISO32 jack hydraulic oil. Arc Euro also sell ISO 32 and 68 oils in 1 Litre bottles. Edited By Gordon Smith 1 on 28/08/2018 17:27:47 |
Thread: Boiler maker with initials DB |
15/06/2018 18:19:22 |
Possibly David Bailey of Bracknell. |
Thread: Picador Type Drill Grinding Jig Modifications |
07/05/2018 10:35:17 |
Graham Meek described some modifications in Engineering in Miniature March 2016 . |
