Here is a list of all the postings Frazer Heslop has made in our forums. Click on a thread name to jump to the thread.
Thread: Is the 4" Rotary Table at ArcEurotrade better than SOBA ? |
02/04/2010 22:11:14 |
Thanks for the infoAndy i will have a look at the Harrogate show as i now need a new rotary table but am now very wary of some of the equipment now on sale as I seem to have had most of this imported stuff fail and it seems to be a waste of material. I had been considering replacing my trusty old Myford with a modern import but will definatly be keeping it now as at least you can buy spares.Sorry for high jacking the thread. |
02/04/2010 19:24:20 |
I purchased a 4inch table made by soba and spent longer repairing it than using until the pinion gave up and no spares are available.On purchase the table moved over 20thou when using the lock screw I remachined the casting and pressed in a close fitting ring then machined the worm to accept thrust bearings and fitted adjustable nuts for back lash after all this the pinion then failed . |
