Here is a list of all the postings Vince Bashford has made in our forums. Click on a thread name to jump to the thread.
Thread: Band saw blade comming off pulley |
08/09/2009 09:51:23 |
Hi Guys,
Just a few thoughts on bandsaws. Some ideas have already been discussed in particular feed rates and buying good quality blades. Also look at the speeds you are cutting at and thickness of material etc. A trick I was taught many years ago is slack off the tension on the blade at the end of each day after use. When fitting a new blade move the guides back out of the way and check the running of the blade manually (without the isolator on) and see how it tracks. Be carefull you do not take off the very tips of your fingers, easily done, then set the guides up once you are happy. The side guides should almost be touching and give the back guide 40 thous/1 mm clearance. If you cut a lot of metal fit a simple coolant system. I hope this all helps, Regards Vince |
