Here is a list of all the postings Quentin Reidford has made in our forums. Click on a thread name to jump to the thread.
Thread: Eccentric Question |
29/09/2013 18:45:20 |
Thanks for your help - I discovered that when I shortened the grub screws I hadn't put back the point! _ so that certainly didn't help the situation. Stew, yes the sheaves are tight when it's all bolted together - I'm not sure how to resolve the situation however, I do not want to remove the eccentrics so pehaps I need to skim the inside of the sheaves - so much for trying to make things a good fit - perhaps I should have gone sloppy fit. Richard, it's a Stirling Single in 5" Consensus of opinion seems to be just edging towards grub screws - possibly with a drill tip hole in the shaft when all is set. Edited By Quentin Reidford on 29/09/2013 18:45:56 |
29/09/2013 10:56:27 |
I am currently engaged in the frustrating exercise of setting valve gear and I have the problem with the eccentrics which keep moving from their set positions on the crank shaft. I have followed the drawings in that I have used two 4BA grub screws per eccentric but I think because the socket head is very small I cannot get the business end of the screw to bite into the MS shaft with any lasting effect. My question is - do I position the eccentrics and pin through the shaft using roll pins? I have only seen reference to using grub screws but surely once the eccentrics have been located on the shaft - are you really likely to want to move them? |
Thread: Model Engineer Survey |
26/04/2011 14:41:52 |
Is an electronic version of the survey available?
I would rather not scan the survey but will do that if it the only electronic means available. |
Thread: Riveting |
28/10/2009 21:02:12 |
I'm just going to source a suitable strip of metal, in my case 3/32" , drill a 1/16" hole in a corner and poke a rivet through the joint and the plate and snip off the excess! |
28/10/2009 20:47:14 |
Jason,
Thanks for that information, does it apply to all diameters ?
I'm using 1/8" and 1/16" rivets?
28/10/2009 20:32:55 |
Can some-one please tell me how much a rivet should project from the face of the metal in order to form a correct round headed head - if you see what I mean.
Using two snaps there must be a formula such as one or one and a half diameters projecting from the face of the steel plate to hammer down into a snap to form a perfect head - I have searched and searched but cannot find this critical dimension anywhere. Any advice would be most grateful before I make a further mess of my current project.
Thanks in anticipation |
