Member postings for Terry Wehling
Here is a list of all the postings Terry Wehling has made in our forums. Click on a thread name to jump to the thread.
Thread: Bench grinder wheel wobble
30/04/2021 21:58:36
I had a similar problem and fixed it with a flange bushing. I made the smaller diameter the size of the hole in the grinding wheel. The flange takes the place of the washer. I had some 2 inch diameter steel and used that. I dished out the flange by about .010 to .020 inches. I left about 1/2 inch on the outer edge of the flange. That way only the outer portion of the flange pressed against the grinding wheel. I used a reamer in the inner hole so that it was a close fit on the shaft. I reused one of the provided washers on the outside of the grinding wheel. Worked well.
