Here is a list of all the postings Roger Vane has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco VMC drawing |
19/05/2011 09:12:35 |
Hi Windy I’ve owned a Warco VMC for a couple of years now and am generally very pleased with it. Your post raises a couple of interesting points. Vibration I haven’t experienced any problems with vibration in the head. Think the key to overcoming the potential vibration problem may be down to selection of the ideal spindle speed – there are huge gaps between available speeds on the VMC and therefore the potential for vibration if the speed selected is not suitable for the job in hand. The information plate in the belt cover lists spindle speeds (50Hz motor) as 190, 270, 480, 560, 1000, 1180, 1379, 1800 and 2100. Based on experience with my old Warco Minor mill, I felt that the spindle speed range offered by the VMC was not really suitable for my requirements – there are no available speeds in my critical range of 560 – 1000 and the bottom speed of 190 is far too high when using a 3” slitting saw. I overcame the problem by ordering the machine with a 3 phase motor with the aim of fitting an inverter to provide variable speeds. As I wanted an R8 spindle and imperial graduations I had to order the machine as a ‘special’ with a delivery time of around 6 months – this approach saved me the cost of buying a new 3 phase motor to make the conversion. I purchased an inverter and remote control station from Newton Tesla – fitting was very straightforward using the wiring diagram supplied. Was it worth the wait? – it certainly was. Do I suffer from vibration problems? – no, as any potential problems are controlled by simply reducing the spindle speed (at the turn of a knob). Other advantages include:
Based on my experience of the VMC, I can recommend that it is a very worthwhile conversion that you might like to consider if it’s not too late. I have found that it puts an ‘already good machine’ into a totally different class. Raising Block The only real issue that I have with this machine is lack of height between the spindle nose and the table. The Warco specification for this is 13.5” whilst mine is only 12.5” – a full inch under specification. This is very restrictive, especially when using their excellent DH-1 vice and a 13mm keyless chuck. I have spoken to Roger Warren of Warco on a couple of occasions regarding this problem. He has told me that he is looking to offer a 4” spacer as a retrofit option to existing VMC owners on the Warco database. The last time that I spoke to him was at the 2010 ME Exhibition, at which stage he was having difficulties sourcing the spacers. Other owners that I’ve spoken to would also like to increase the capacity of their machines, so this appears to be a real issue. I can only suggest that owners of VMCs who feel that this is a problem contact Roger Warren direct and push this matter forwards. Let’s have some ‘people power’ to resolve this problem. Hope that these comments help. Regards,
Roger. |
Thread: Slideway guard on warco vmc milling machine |
18/02/2011 15:24:07 |
Had exactly the same problem - managed to destroy my rubber cover within a few days from new.
I made a simple cover from leathercloth and a piece of angle iron which covers the Y-slide (but not the vertical). I felt that the real problem was stopping swarf from getting into the gearing which elevates the knee and this has provided the ideal solution so far (18 months).
The angle iron simply clips into the 'slot' formed between the knee casting and the 'recess' in the centre of the Z-axis slideway. Hope that the photos explain all.
The leathercloth is thinner and more flexible than the rubber and allows the slide to go back against the stops, maximising travel. An added bonus is that the Z-axis slide is uncovered and provides an ideal mounting surface for a magnetic clock stand.
Thread: DRO for Myford ML7 |
22/02/2010 16:55:04 |
Re: SINO SDS6-3V and number of decimal places ......
If you are working in imperial measure and have readings to 5 decimal places and wish to change to 4 decimal places then it's worth trying the following procedure.
Switch to metric measure, and then back to imperial (using the 'M/I' button) . At this stage you will have the option to set the number of decimal places used for imperial measurement. Select 'MORI4' in the display by use of the 'up / down' arrows and then hit 'ENT' - that will give you the desired number of decimal places.
Hope that it works for you. |
Thread: Simpler the Better -what do you use? |
19/02/2010 12:11:58 |
Hi Kwil,
When drawing a line with TurboCAD you can 'lock' it to either the vertical or horizontal direction using the 'ortho' snap mode, which limits the drawing of lines to 90 degree angles (0, 90, 180, 270). Other software may well have similar functions.
However, I'm not really certain why you would want to do this on a regular basis as using ortho turns off the other snaps (such as vertex and intersection) which are more useful as aids to precise drawing.
Hope that this helps.
Regards.
Thread: ME Centennial |
27/11/2009 12:01:32 |
I've just checked mine and although the pdf has 25 pages this includes the initial 'copyright advice' page - page 25 of the actual document is missing. |
Thread: oil |
22/10/2009 17:38:04 |
Yes - you rotate the key 3 to disengage it and lift the lever 4 as you were doing previously (to engage the backgear gear train). The resulting drive will still be forwards though - to reverse spindle direction you must reverse the motor. Good luck. |
22/10/2009 17:11:07 |
Hi Allen,
Your backgear problem - have you disengaged the back gear key - item 3 in the diagram page 22? If you haven't then everything will jam up as you describe. Simply rotate to disengage and then the backgear should work ok.
Regards |
Thread: Stent Tool Grinder |
29/09/2009 12:21:50 |
Hi Fred, Quorn or Stent? Let me start the ball rolling ….. I too had the same dilemma – I wanted a small T & C grinder, but was it to be the Quorn or the Stent? In the event, I chose the Quorn and completed construction over a period of several years. The Stent as designed is a fairly crude machine whilst the Quorn appears to be far more sophisticated. Was this the right decision? Although the Quorn will carry out many operations, particularly with special attachments, I have become increasingly frustrated with it. The main reason being that, apart from movement along the bed bars, other movements involve the generation of arcs rather than straight lines and therefore there are no graduated linear scales. This makes it very tedious to use (for me anyway). The Stent on the other hand has normal linear movements and graduated scales. I had decided to stick with the Quorn until I read an article by Charles Woodward in MEW 137 (April 2008), in which Charles appraised both machines and described how he had modified the original Stent design into what might be termed a ‘Super Stent’. This is well worth reading and may help you to make the final decision. Charles has now written a further series of very helpful articles, currently being published in MEW. There has also been a series of articles on using the Clarkson in recent issues of MEW and as the Stent is based on the Clarkson, these too have been very helpful. My problems were resolved, and I decided to build the Super Stent, but with a few more modifications of my own – primarily to utilise the Quorn principle of interchangeable wheels and maybe some of the tooling (as I already have these). This now involves some more redesign, particularly the spindle which needs further ‘beefing-up’ due to the hole required for the drawbar. Detail design work is now well under way for the main assemblies, and I hope to start cutting metal shortly. Overall, my own opinion is that properly ‘tooled-up’, the Super Stent is the better option, although I’m sure that the two machines will compliment each other, with some jobs being better done on the Stent and some on the Quorn. Hope that this helps - what do other people think? Prices – a shock here I’m afraid. I bought my Stent casting set from Blackgates in July 2008 just after a price increase due to foundry costs – cost of castings and drawings was around £320. I believe that Quorn casting prices are very similar. Regards. |
