Here is a list of all the postings steve kendall 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Electronics in retro fit of CNC control on X3 Mill |
26/10/2010 17:23:46 |
I have been reading the excellent article written by Dick Stephen in Dec 2004 to March 2005 MEW about retro fitting CNC control to the X3 mill. As I am far more comfortable with the mechanical side of the project, I intend to build the electonics side of the project first . I am looking at the manual control box at the moment, the diagram fig. 9 on page 33 of Feb/Mar issue shows one 7490 IC, but the parts list and photo 25 shows two of them. I assume that due to my lack of expertise in electronics I am missing something obvious. Can anyone help?
Steve |
Thread: 2 start thread on fountain pen |
15/09/2010 22:37:31 |
Hi Neil
That's a good idea, it will solve my problem and I can start using my pen again!
Thanks
Steve |
15/09/2010 09:49:56 |
Hi
I have lost the cap for my stainless steel fountain pen and I am trying to make a replacement. As near as I can measure the thread seems to be square form, major diameter 12.7 mm, minor diameter 12.1 mm, pitch 1.6 mm per rev. number of starts 2.
I have read Screw cutting in the lathe, and found it nery helpful.
I have ground a HSS tool 0.4 mm wide, and cut an internal thread on a piece of scrap brass. This almost fits, but does not run freely. Does anyone have any advice, particularly on measuring and identifying the thread form?
I am using a SEIG C4 lathe using 16 TPI screw cutting feed, and I move the compound slide 0.8 mm to make the second start. I have made a tap from silver steel and hardened it but I am having difficulty using it to cut a thread, I think because it is square form.
Can anyone help?
Will anyone with cutting threads be at the Myford open days so I could show you my problem and efforts so far?
Steve |
