Here is a list of all the postings trevor jones 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: INDEXABLE LATHE TOOLS |
11/05/2010 21:37:19 |
hello
i have only used carbide tipped lathe tool on my C3 lathe i now want to buy some INDEXABLE LATHE TOOLS any advice please were to buy what to get what size
thanks
Trevor |
Thread: cutting morse taper |
22/03/2010 15:22:57 |
ok i had a go at makeing MT2 but in the end i think i will buy from arceurotrade thanks for all your help.
and Ian thanks for your encouragement
Trevor. |
15/03/2010 13:18:49 |
I have been looking at makeing a morse taper MT2. On the internet theres lots of info but what size diameter round bar do i start off with and are there any tip that you all mite have.
thanks
Trevor. |
Thread: Convert cheap digital calliper to height gauge? |
01/03/2010 15:52:18 |
febuary 2010 MEW 160 has plans for home made height gauge.
Trevor. |
Thread: marking blue |
19/02/2010 23:09:42 |
ok thanks.this stuff will last me for ever then.
thanks to all. |
19/02/2010 22:21:27 |
ok ray this is called stuarts micrometer engineers marking i asked the fella in the shop for marking out blue for scribeing.
Trevor. |
19/02/2010 21:36:38 |
Posted by trevor jones 1 on 19/02/2010 20:55:16:
ok john you say soak and puddle this is thick like grease do i dilute it
19/02/2010 20:55:16 |
ok john you say soak and puddle this thick like grease do i dilute it |
19/02/2010 19:31:02 |
whats the best way to apply marking blue bought some stuarts engineers marking today any tips.
Trevor. |
Thread: steel price |
12/02/2010 12:02:01 |
ok les i forgot to say ask for off-cuts first there at the back of the place. i dont no about sheet but theres a few steel stockist around there.
Trev |
12/02/2010 11:31:31 |
ok les. scimitar steel
Admiral Works 3 Benbow Street Bootle, Merseyside L20 1EP |
12/02/2010 00:00:28 |
well the 25mm round bar is for some dumbells i'm makeing and the 12x50 is for the bracket on the tailstock turret in this months MEW i no its only 68mm long but the steel i got were off cuts they dont cut peaces off off cuts. and the blocks were because i'm a magpie
maybe for some kind of tool post |
11/02/2010 22:49:36 |
would you say this is good value for money its from a steel stockist in Liverpool all bright bar all for £20
2ft of 12x50mm flat
3ft of 25mm round
4in of 65mm x 65mm sq
6in of 50mm x 75mm flat |
Thread: MT3 TO MT2 OPEN SLEEVE |
06/01/2010 17:02:27 |
ok Ian I done it this afternoon the problem was how to lock the spindle
![]() Trevor ![]() |
05/01/2010 20:22:15 |
OK Ian theres no flang on this sleeve but theres two flats for a spanner the mill iv got is a
Axminster SIEG X2 Mini Mill |
05/01/2010 20:10:26 |
OK KWIL i tryed that this afternoon with no joy its solid the only thing to hold the spindle with when tightening your gizmo is the spindle nut but all it was doing was tightening that so i give up and went and had some big soup it was freezing. Trev ![]() |
04/01/2010 20:56:47 |
Hello i have got a MT3 toMT2 open sleeve stuck in my milling machine theres no thread for a draw bar will someone please tell me a beginner how to remove it Thanks |
