Member postings for Mike.H.
Here is a list of all the postings Mike.H. has made in our forums. Click on a thread name to jump to the thread.
Thread: True Diesel Models
29/12/2010 11:53:39
Many thanks to all who have responded, there is loads of stuff to follow up on  .It seems i may have raised a little interest and will try to do some serious basic design work time permitting. Mr Howard Jones's  advice re Avtur is v interesting . Once again thanks to all
                     Mike.H.
19/12/2010 11:34:09
I am considering using an Armstrong siddley 6hp (600cc) single cylinder stationery engine as a prototype for a model ic  design project. As he scale is yet to be decided i thought it might be a good idea to ask if anyone has made a succesful 4 stroke diesel as i have not seen one discussed or exhibited anywhere. I would expect the fuel to be standard diesel fuel ,bur some rough calculations suggest that ignition additives may be neededany ideas??Mike H
Thread: Ignition coils for small engines
13/01/2010 11:00:33
Hi all
   Coils available from automotive sources though functional are often too large for model use . I recently owned a renault Megane which had one coil per cylinder built onto the end if the plugs . The primary on these was 12v and the whole assy was quite small . There may be some mileage in modifying these .
   Mike H.
13/01/2010 11:00:24
Hi all
   Mike H.
Thread: acid pickle
24/06/2009 15:29:33
How about using Citric acid I find it works fine ,and the home brew shops dont employ elfins
   Mike. H.
