Here is a list of all the postings KWIL has made in our forums. Click on a thread name to jump to the thread.
Thread: I like a nice tool but.. |
02/08/2023 13:03:26 |
There is another japanese saw that is useful, with no set on the teeth you can cut flush without marking the surface. |
Thread: Why do modern car engines have different types of bolt type heads like Torx etc? |
27/07/2023 18:31:05 |
There is one great advantage in having UK sources of oil and coal (including new Oil and new coal) is that you SAVE the transport costs and emissions bring it from far off places for as long as we need it to allow the green steps to be safely taken. Anyway, how much of the worlds emissions do we contribute? Quite a low % I would guess. |
Thread: Gluten Intolerance |
21/07/2023 10:01:32 |
DMB, Hydrolysed Vegetable fats = margerine Other contributors Sourdough bread is equally disgusting Cadbury chocalate has become like all USA choc ugh! Is IBS just a generic term to cover all effects not properly understood as a specific problem? |
Thread: Spitfire in aluminum. Metal art display model |
20/07/2023 19:17:43 |
Much work done done following experience with the Schneider Trophy float plane during the earlier 1930s.. From personal experience it flies like it looks, a dream. Edited By KWIL on 20/07/2023 19:18:27 |
Thread: Scams |
13/07/2023 19:21:23 |
Harry I too received the email you show. to an email account I own, but do not use for purchases!! Put in my trash bin, K |
Thread: Boiler makers in 2023 |
13/07/2023 10:26:27 |
Posted by Nigel Graham 2 on 12/07/2023 22:43:49:
The last couple of issues of ME show only Maidstone and Western Steam, and they make only copper boilers. Souhern Boiler Works are still very much in the business of copper boilers. |
Thread: Workshop Clock |
05/07/2023 08:34:36 |
I have not used Duracell batteries for some time now because they are more likely to leak, causing damage to whatever they were being used for.. |
Thread: Old tools restoration |
03/07/2023 13:20:49 |
Typical King Dick adjustable spanner. |
Thread: Replacement Bearings - Myford ML7 Motor |
29/06/2023 14:33:42 |
I am somewhat sceptical about the motor bearings being white metal (inspite of the infomation stated). White metal bearings need more than infrequent lubrication and I have not seen a ML7 motor with other than just a hole that endeavours to fill up with swarf. Am I wrong? |
Thread: Cure for Tight Nuts |
24/06/2023 09:52:18 |
The metal flow when goughing reminds me just like the metal and dross flow when using a thermic lance to cut concrete. |
Thread: All things Beaver Mill |
07/06/2023 09:40:07 |
Air Drawbar pic for Bridgeport |
07/06/2023 09:22:43 |
I made and fitted a pneumatic drawbar for my Bridgeport, what with its riser and off floor pads, the top is quite high. Works every time without locking the spindle although I can if I wanted to. |
Thread: End cutting in mill |
01/06/2023 14:04:24 |
You could always try https://www.greasemonkeydirect.com/collections/copper-washers They have a very large range
Thread: Any idea where to buy? |
26/05/2023 15:58:27 |
Bags of hen's teeth also available Unlikely to find any as Philips x head screws were not available in BA sizes.(afaik) |
Thread: What does this symbol mean? |
24/05/2023 20:17:34 |
I am sure it shows what it says. Two identical windings, 1:1 ratio, Completely isolated for safety. In other words an isolation transformer. |
Thread: ME4717 Miscollation |
22/05/2023 11:23:30 |
Me too 11.00 this morning |
Thread: Myford levelling on industrial stand |
17/05/2023 19:30:45 |
Myford Series 7 machine aged raw castings were inverted and the 4 feet machined to a common level. The casting was then placed the right way up and secured to the machine bed. The top, front and rear ways were then machined to the correct outline before being transferred to a grinding machine when the final profiling took place. None of the 3 Myfords I possess have been difficult to "level". If you are making your own raised mounting blocks, a threaded pipe reducer makes a good adjuster, before tightening the throughbolt as required. This enables the block to be bolted into position first, so you are dealing only with the minor variation in height that may be required. |
15/05/2023 13:22:46 |
I simply telephoned Mortons and a new complete copy is in the post. Mine had merely many missing pages and hence was thinner. |
Thread: Recommended viewing - Artificial Intelligence |
14/05/2023 10:58:05 |
Micheal, I am gratefull for your information, (as usual) K |
14/05/2023 10:28:02 |
Micheal, How far into the programme? I cannot stand LK's incessant nagging to await the correct time. K |
