Member postings for Chubbs
Here is a list of all the postings Chubbs has made in our forums. Click on a thread name to jump to the thread.
Thread: info.
20/06/2018 13:51:11
Hi.
Can somebody please tell me how to deleat a add that i have put on here ?thanks.
chubbs
Thread: Shaper Motor Direction
04/02/2018 19:02:11
Hi all.
Thanks for the reply s , and to Brian yes i can see now that there is a direction arrow on the drum.smiley.
Once i get the motor on and clean it up a bit i will have to get my head around setting it up . After reading and watching You Tube , i still am not quite sure on setting the ram in connection with the crank. ??
All for now. John.
03/02/2018 18:06:17
Hi.
Can someone tell me which direction the motor turns on the 10M. And does it make any difference which way it turns.
Am having to fit a new single phase one on a machine that i recently got , with a shot motor on.
Thanks John.
Thread: thread dial
26/11/2017 17:10:38
Hi all.
Have all the info i need now, thanks for your reply s , all is clear smiley now. just need to try it out.
Chubbs.
20/11/2017 12:18:28
Hi all.
Can some one tell me if a 8TPI leadscrew, Dial Indicator Pick-up chart, will be the same for a 4TPI leadscrew chart. ??
Thanks. Chubbs.
Thread: Midlands Model Engineering Show at Warwick
19/10/2010 20:14:54
Hi all.
I attended the show as per usual on the Sunday, and the first thing i noticed as i got inside was the size of Warco, s stand to what they mostly have, and as i walked around i saw that a few more Companies had down sized there stand. Also a few that are normaly set up wert even there.??????
Is this a sign of the times or are the fees getting to big for the stalls to afford . ??
Any body else notice this.
 But on the whole a good show.
        Chubbs.
Thread: Making Gears.
15/10/2010 19:27:45
Hi lads.
Thanks for the replys,  &   Stubs o k  about being more accurate will do.
Also i did click on the FORRESTMOON that Paul posted and that seemed the dogs ---------  but 5 mins later my P C went tits up from a corrupt file now weather it was the forrest file or not i dont know ???. Can anyone shed any light on that ????
So i am a bit afraid to go back to that again.
                           Thanks again                       Chubbs.
12/10/2010 20:40:44
Hi all.
I am thinking about making some gears for a Boxford Lathe, but at the mo i am trying to get my head around working out the gear blank size. (never any good in maths).       For a gear with 55 teeth.
As i see it ,from what i have read up on,   55 teeth  + 2  over  18 D P  gives me 3.17    , is this fig 3"  &  170 thou   the dia of the blank ??
    thanks for any input .                       Chubbs.
