Here is a list of all the postings Roger Webster has made in our forums. Click on a thread name to jump to the thread.
Thread: warco/amadeal 250-550 lathe |
22/07/2023 15:47:51 |
Yes I can see there is some miss alignment with wear on the half nut carrier bushes. I have made a beefed up double carrier and will attempt to realign the half nut, carrier, lead screw and bushes
Could be difficult!!! |
22/07/2023 14:44:00 |
I have the amadeal 250 lathe fitted with a Rocketronics electric lead screw. All operates as it should but I notice there is only one half nut and there is some wear on this item after only moderate hobby use Does the Warco lathe have a pair of half nuts? I intend to modify my lathe and fit a pair of half nuts to reduce the stress and wear on this item As a stop gap and to allow the lathe to be used to make some bushes etc I have fitted a 16mm x 5mm pitch cheap ball screw and spindle. It works suprisingly well. I was concerned about the increased pitch from 2 to 5mm but no problems so far with fine feed rates and the Y axis motor overheating
Thread: How to get 9° .38' on a dividing head? |
04/05/2023 13:12:50 |
Thank you all for the very swift advice. I will convert the 17 hole A plate to 34 holes. Simple and cost effective solution
04/05/2023 11:53:10 |
I have a Soba HV-6 dividing head DP1 I need to cut a 68 tooth gear but this is unavailable with the supplied A B C plates Is there an easy solution please |
Thread: Boiler brazing |
23/07/2009 09:18:03 |
I am about to braze up a 4" vertical boiler similar to the Tina engine and boiler avertised in the magazine What is the best order of work ie should I braze up the tubes and tube plates and then attempt to fit them into the boiler tube? Alternatively is the best way forward to assemble the complete boiler and braze the whole thing in one operation Your expert advise would be most welcome |
