Member postings for Brian Brown 1
Here is a list of all the postings Brian Brown 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Hunslet 5" Loco
28/07/2009 18:22:55
Hi all,
I'm currently approaching completion of my 1st locomotive, a 5" Hunslet to the Don Young design, but try as I may, I have not been able to form the brass cowling that wraps around the rear of the firebox backplate / outer wrapper joint. The cowl is a 2" wide brass strip in half round section and is curved through a 17 1/2 " diameter for 180 degrees, with the remaining legs on either side continuing half round but straight in order to cover the vertical joint.
I hope that makesense!
I've tried clamping sheet brass between 2 formers and heating/beating, but I still end up with creases. I've also tried forming a half round srtaight section and coaxing it around the radius, again to no avail. Pressing seems to be the answer, but I don't have the means or wherewithall to machine a set of dies.
I realise that the cowl is purely cosmetic, but as it adds immeasurably to the appearance, I would really appreciate some advice as to how approach this task before I ruin any more sheets of brass!
Many thanks,
Brian Brown
