Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: Change Wheel Programme from MEW |
28/08/2021 15:52:06 |
If you just want a program to use rather than worrying about BASIC etc;, look for NthreadP on Lathes.co.uk: It works straight off on Windows machines and under Wine on Linux. There is another version for lathes with a screw cutting gearbox. Russell |
Thread: To Cap It All |
28/08/2021 15:14:03 |
I would be inclined just to buy one new. I've had good service from the Seven Workshop in the past. Probably cheaper than a chunk of bronze to make one. Russell |
Thread: small white spots |
26/08/2021 11:33:35 |
My go to reference is: "Linux Command Line and Shell Scripting Bible", by Blum. Russell |
Thread: Soldering brass |
26/08/2021 11:25:33 |
Posted by Keith Hale on 26/08/2021 09:57:49:
I am reminded of the occasion when a model engineer told me that he insisted on making his own special alloys (3!) to make a truly authentic samurai sword. My response of £1m was not what he wanted to hear!
Where would he use silver solder on a samurai sword? I have a 500 year old katana and I can't see where it would have been soldered. Russell |
Thread: Clinging to the Past |
20/08/2021 19:24:31 |
Posted by oilcan on 20/08/2021 18:54:08:
isn't the number system in the french language base 20? It's a horrible mixture of tens and twenties, tens up to fifty and twenties up to 100. I still find it difficult after 18 years in France, especially with telephone numbers which are always spoken as pairs of digits from 00 to 99! Russell |
Thread: Keeping fit and the economy |
20/08/2021 16:27:41 |
There was an advertisement in the 1920s for the Austin 7 that claimed that the total running costs of that car was less than 1 d. per mile and that it was less than the cost of walking and replacing worn out shoes. Perhaps we should all drive rather than walking to the shops to save the planet???? Russell |
20/08/2021 16:07:30 |
Posted by Vic on 20/08/2021 12:50:43:
The influence of imperial measurements is still very much evident today. For some youngsters sheet goods must seem to come in weird sizes like 1220 x 2440, until you look at a tape measure. Also look at socket drives - 1/4”, 3/8”, 1/2” etc. I’m sure it must upset the French. You would have thought the EU would have replaced them with metric sizes by now. 😂 I don't see why it should upset the French. For many years they used the pouce (thumb) which was 1/12 of the pied (foot) and very close to the British equivalents. Indeed they still use BSP threads for domestic plumbing fittings, although named according to their approximate thread OD in mm. Russell |
Thread: Consequences of Machining Cast Iron |
13/08/2021 14:20:37 |
+1 for oxalic acid. Also good for cleaning teak on boats. Russell |
Thread: How Elgin made Jewels for Chronometers |
24/06/2021 15:47:35 |
Posted by Circlip on 24/06/2021 13:02:31:
Trichlorethylene, ( pre Ethane) Carbon Tet, Ether, Nitromorse Sulphuric acid, how the hell have I managed to survive to mid septagenairian. Regards Ian. Add to that mercury being played with at school, making various explosives in my parent's garage (the best one was nitrogen tri-iodide), etching glass with hydrofloric acid, etc. Regards from another mid septagenarian surviver. Russell |
Thread: 2D and 3D Cad Software Recommendations |
23/06/2021 09:51:30 |
+1 for Onshape. I have used Solidworks in the past (before retirement) and I find Onshape similarly intuitive to use, being produced by a group of ex Solidworks people, so I might be biased. It is free and shows no signs of disappearing after six years or so. It will export STL files for 3D printing and create 2D drawings from the model. The only downside is that, being browser based it can get rather slow for complicated models. I have however managed to import a complete Antikithera mechanism into it so it will certainly handle most of our needs! Russell |
Thread: 2.5mm thick mystery 'Formica' type sheet. Is it still available? |
14/06/2021 10:43:16 |
Posted by Robert Atkinson 2 on 13/06/2021 21:08:16:
If it is for an RF window I'd be wary of decorative materials. many of them are lossy at Radio Frequencies. A particular problem is melamine. It is very lossy at RF and is used a a facing material in formica and similar. Depending on frequency the phenolic board I linked to earlier may be OK. Names for this are FR-4, G10 and Tufnol "Glass". G10 at least is available in black. Robert G8RPI. Edited By Robert Atkinson 2 on 13/06/2021 21:09:02 For RF transparency I would avoid any black plastics as the common pigment used is carbon black which will make it rather lossy depending on frequency. For making printed UHF antennas we used to use clear high impact polystyrene but I guess that is not what the OP wants. Russell Russell. |
Thread: Machin guards |
13/06/2021 16:24:05 |
Polycarbonate. Russell |
Thread: Blueish steel |
31/05/2021 10:34:32 |
I've found Abbey blue gel to be effective and long lasting. I've used it on an old Laguiole David knife that a visitor had put in the dishwasher and removed the original blueing! After use they should just be wiped down with a drop of red wine to clean and sterilise them. Just dip your finger in the wine that accompanied your steak! Russell |
Thread: College Engineering Supply Castings Alternatives? |
19/05/2021 16:38:40 |
When I bought my first milling machine, about 17 years ago, I followed Harold Hall's "Milling a complete course" and found it very instructive. The first project after making T-nuts was an angle plate, again using the CES castings. While buying chinese angle plates is quicker and cheaper that doesn't give a beginner the same experience. I commend the OP for trying to take that route. Russell |
Thread: Porsche 951 |
12/05/2021 09:49:54 |
Posted by Peter Seymour-Howell on 11/05/2021 18:34:30:
One of the secret weapons on this engine, the two balance shafts that give this big 4 pot the same smooth running as a straight 6.
Not much of a secret. Lanchester used that idea back in the 1930s they even used it with the shafts geared up to remove vibration harmonics on six cylinder engines. Russell Edited By Russell Eberhardt on 12/05/2021 10:03:46 |
Thread: Advice on removing column from mini-Mill |
10/05/2021 10:21:41 |
If it's the X1 type mill the column should come off O.K. with the nut removed. I would try a bit of penetrating oil and work it up and down a bit as you pull. ARC have some dismantling guides on their websites for their versions that might help. Russell |
Thread: Ropey Radio Reception? |
10/05/2021 09:04:46 |
Unfortunately very few FM radios are fitted with a proper aerial socket and the built in whip aerials are woefully inadequate. For best operation a whip aerial should be 1/4 wave, that is about 75 cm, long. The other problem is that in a house the signal will come from multiple paths each with a slightly different delay and interfere with each other. For compact reliable reception a WiFi receiver of some sort is much more reliable and easy to set up. Russell |
07/05/2021 10:37:32 |
Posted by Nigel Graham 2 on 05/05/2021 17:50:41:
Also I tend to rely on the radio for verifying my clocks and watches - have they sorted out the problem that DAB radio notoriously delayed reception?
If you have an Android phone or tablet the "ClockSync" app gives you clock time derived from NTP with better than 10mS precision. Alternatively there are GPS time apps but they (only !) give 300 mS precision due to deficiencies in Android. Russell |
05/05/2021 15:36:38 |
I have suffered similar problems for years with my FM radio alarm clock. Some days good reception of our local (about 15 km away) radio station other days reception would come and go as I walked about the room. DAB is not available in this area. I spent about £40 on a Google Nest Mini and told it to set a daily alarm for 7 AM and play our local station. I can also use it to play any one of thousands of radio stations by just saying "Hey Google, play BBC radio three" for example. The sound quality is much better than I expected from such a small device but if I want real quality I can cast to my TV which outputs sound to my HiFi. Russell |
Thread: Reading glasses - frosted area |
04/05/2021 11:03:09 |
If they are glass, use jeweler's rouge. If Acrylic use Perspex polish but note it's not suitable for polycarbonate. Russell |
