Member postings for Fred Graham 1
Here is a list of all the postings Fred Graham 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Good morning all, new member here.
13/10/2021 17:46:04
Hi Subscribers
I am a newcomer and would like someone to tell me, as a digital subscriber to what that gives me access I have been able to look at model engineer for some of the current magazines but if I try to look at any prior to my recent subscription they do not display. and I simply get a blank screen. I thought I would be able to access previous volumes? Is my subscription limited to the current volumes and if it allows access to previous volumes why does my subscription show blank pages.
I seem also unable to print out any articles which interest me as some articles do not and I would like to store articles of interest. Do I need a different subscription to be able to do this.
Is there a comprehensive set of user instructions as it is not immediately evident how to perform some actions which may be possible
10/09/2021 12:10:07
As as octogenarian I find getting around digital stuff quite tricky and this site is no exception
My name is Fred and I make model steam boats and design and make all the plant from scratch and have done so for many years. I am also interested in Flash steam.
I have a digital subscription (£50) to Model engineer and seem to be able to read magazine articles on my desk top. In the past it was possible to print an article which interested me so that I could read it by my fireside. I am not interested in every article, mostly steam related things.
If I do want to print any article I now find that I cannot do so. I wonder if that means I need to upgrade to digital + print.
I contacted the site respondent to determine if this was indeed necessary and quoted a code but she did not seem to be able to advise me.
In despair I have given up and now simply read the articles at my desktop and presume that the older less tech savvy must simply do without printed copy, which does seem as shame.
My other interest is in the forum in which there seem some interesting discussions. I wondered if it is possible to copy any of these and paste them into Word or other word processors(I still use IBM Lotus Wordpro)
Otherwise I think subscribing to the magazine is not worth it for me.
All the best to Tech Savvy folks, Fred
Thread: LPG Gas jet sizing
07/09/2021 15:10:27
Hi folks,
Thanks for comments and especially Roger, OOPs did not notice that link on Forrest Classics, What a plonker!
Lost inside a paper bag and can't find the way out and poor explorer, to boot. Thanks again for keeping me right.
They seem to have a good range and reasonably priced too!
All the best, Fred
07/09/2021 08:40:04
Hi Harry,
Thank you for the Link but they don't seem to sell Jets. I tried there 'search bar' and it came back as not recognised, so it look like another supplier not stocking them, which Is surprising.
I will contact them again and see f I can get a clear 'yes or no' response.
All the best, Fred Graham
06/09/2021 19:43:02
Hi Folks,
Does anyone know who supplies jets for burners as most of the suppliers of boilers and burners do not seem to.
I found one the does called 'Maidstone Engineering Supplies' but there must be others. Someone mentioned a 'Usual supplier ' Who might that be?
06/09/2021 19:30:54
The first one should be 0.2mm not 0..2
Fred Graham
06/09/2021 19:29:37
Hi Folks,
Although I cannot, personally, vouch for these sizes they came from a good source, Mike the former MaccSteam boiler maker now retired
The sizes are Number 3 has 0.15 mm jet bore
Number 5 has 0..2mm jet bore
Number 8 has 0.25mm jet bore
Number10 has 0.277mm jet bore
Number 12 has 0.3mm jet bore
Number 16 has 0.35mm jet bore
I hope that will add some more to the general information source
All the best Fred Graham
Thread: How Much Steam Oil
14/09/2015 16:56:31
Hi Folks,
Long time, no communicate!
I am interested to hear if someone using an oil pump, rather than a displacement lubricator, which seem most popular. Has anyone got any ideas about how much oil should be delivered to a steam engine. Although a respondent to the query suggested so many revs of the engine to one stroke of the pump, this must depend on the size of the pump and the swept volume of the engine. With a large swept volume and a small swept volume pump too little oil may be delivered and vice versa.
I have looked in vain for some technical data about steam engine lubrication but most times I find only displacement lubricator information. There must be some relationship between film thickness and internal engine surface area to be lubricated per revolution and the capacity of the oil pump to deliver this quantity continuously and reliably.
Perhaps I am being far to pedantic and most people would say, "as long as there is oil going in and the oil trap is filling up don't worry" but it does sound like an interesting subject to investigate, doesn't it?
I would be interested in any guidance on the subject especially if it is not a bundle of differential equations and lots of needless mathematical complexity'
All the best and happy steaming, Fred Graham
Thread: New print and digital subscriptions
24/02/2011 10:31:43
Hi David,
It does seem to take a while for access to digital vesions of the Model engineer. I ordered mine at the end of January and after a fortnights hliday I found that I had been subscibed to Workshop by mistake. I let them know straight away and I am still waiting. They said it would take 10 days to make the ammendment to my subscription.
Presumably once it has been made available on line it will be simple procedure to access the magazine!
Sorry to whinge but you seem to be the guy who soaks up any flak!
Best Regards, Fred Graham
Thread: Water Pumps
07/06/2010 13:07:08
Hi Folks,
I have noticed that some commercial model engine suppliers (E.G. Hemmens and Monahan) have water pumps driven directly from the crank shaft. They also have the valves arranged in a horizontal manner.
In all the Model Engineering mags, water pumps are usually geared down to 4 or 5 to 1 to avoid innefficiency, I believe, and the valve boxes are always vertical so that there is a degree of 'gravity assist' to valve seating.
If anyone is using plant  with these characteristics, I would be interested in their experiences of performance and reliability.
Thank you, All the best, Fred Graham
Thread: Steam turbines
06/10/2009 14:37:25
Hi Windy,
If I am not mistaken are you Paul Windross as your flash steamer does look familiar? If it is Paul, Hi again, my name is Fred Graham who sometimes comes to Hull with Tom Clemment and Bob Kirtley.
You may be interested in a booklet from Camden Miniature Steam Services written by W M. J. Cairns in which he describes deatils of the TESLA turbine. There are also drawings of a small version which does not seem too difficult to make and seems to offer good power output possibilities. There are no blades invlved and a lot of the bits are made from good quality duralumin, good for keeping the woeght down on flash speedsters. I am pretty sure they still sell spoies but in case you cannot get it I have a copy and you can borrow it.
All the best and I hope you are in good health.
Fred Graham
Thread: MEW Just gets better
12/06/2009 17:15:33
Hi
I have to agree with John Wood about David Clark. He seems to have an instinct for what the readers want and he is a good listener who responds to comment, good or not so good, in positive manner.
The format keeps on getting better and I like the contributors photos (of themselves) as you feel that you know them without ever meeting.
I look forward to Davids evaluation of the survey and hope that marine plant has a slightly larger coverage, but them I am biased more than a little. Marine plant seems to generate lots of innovative ideas or variations on old ideas from many contributors where scope for new ideas on the more popular locos and traction engines is limited by the constraints of the prototype.
I am still, however, in awe of the output of such models with the quality and finish which exponents achieve.
Meantime all the best to readers and thanks to David and the ME Team
Fred Graham
Thread: Martin Ransome Water Taxi Steam Launch Florence power plant
12/06/2009 16:56:55
Hi,
Delighted to see the first article by Martin. Martin's boats are a treat to see; his workmanship, both mechanical and woodworking, is immaculate. Looking forward to the rest of his series and it is good to see that Model Boats are being covered again after what seems a long absense.
Anyone out there into flash steam. The last articles I can recall were by Bob Kirtley, for a round the pole hydroplane 'Pisces' with flash boiler recording world record @120 mph or thereabouts.
It would be a treat if another Edgar T Westbury was a contributor as articles of this calibre were very inspirational
New site looks great and look forward to regular viewing
