Member postings for Southern Sailor
Here is a list of all the postings Southern Sailor has made in our forums. Click on a thread name to jump to the thread.
Thread: Lighting
22/09/2012 20:28:04
Hi again ME forum, Southern Sailor here. I posted the same query on Model Boat Mayhem forum and received very helpful and informative replies, one of which was:
"Actually it is a problem & can cause very dangerous situations around any rotating machinery. You should always in addition to fluorescent light also have an incandescent light as well where you have rotating machinery. As you will see most machines have their own incandescent light fitted, especially grinders & lathes. Fluorescent lighting causes a strobe effect & will make under certain circumstances spinning machinery to actually look stationary, very dangerous. As an aside in hockey rinks they nearly always have an incandescent light above the the net to eliminate the strobe effect on the puck so that it does not create an optical illusion on the goalkeeper. Mick B."
I have reproduced that reply here to pass on some good advice. I will, as a result of the mayhem suggestions use electronic balasts for my workshop.
Sail on sailor
