Here is a list of all the postings Chris Edwards 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Upgrading from a Clarke CL300M, where to go? |
03/10/2023 12:29:15 |
Hi Bill, Thanks for the review, it really does help to an honest appraisal of the machine! It's definitely not out of the picture for me and knowing that it is accurate to it's description is good to know. They really should list all the extras, it would make this process a whole lot easier! Cheers, Chris. |
02/10/2023 22:12:39 |
Hi Everyone, First of all I would just like to say many thanks for all your comments and the time and thought you have put into them. It’s great having a forum like this as you guys raised points I hadn’t even considered! What I think I can take away from your advice is the following; 1. Try and get the largest / sturdiest machine possible within the space available. 2. New over second hand will always be a BIG dilema. I have bought both (different machines) and I think at the end of the day it really comes down to research, testing and how good the deal really is. 3. While certain specifications can seem great is there actually an advantage i.e. a 38mm spindle connecting to a 125mm chuck..? 4. Geared over variable speed? I like to multi use my lathe from time to time and having variable speed makes that easy (even if there is a chance of electronic failure in the future). I’ll take all this information away and have a good think before opening my wallet! Many thanks, Chris. |
30/09/2023 21:23:55 |
Hi Dave, Thanks for the advice regarding the bore size, that had actually been one of my concerns and the reason I quite liked the look of the Amadeal machines AMABL210D or AMABL250 (https://www.amadeal.co.uk/acatalog/AMABL210-Brushless-Lathe.html) and their prices seem quite fair. I'm guessing the difference in price between the Amadeal and Cratfman machines is the addition of the DRO or are there other reasons why one would choose one band over the other? Considering one of the big flaws of the CL300M is the timing belt and plastic gears (although I have upgraded these to metal) does a geared head offer better reliability? Cheers, Chris. |
30/09/2023 10:16:14 |
Hi Nick, Thanks for your detailed response. The Warco lathes sound interesting but they seemed to be priced higher than the Amadeal and Craftsman machines. The specifications seem quite similar so is this just an attempt to make them look better than other manufactures..? I've also got a lot to sell with my CL300 which will make the purchase of a new lathe less of a dent on the old wallet. Cheers, Chris. |
29/09/2023 22:08:01 |
Hi Howard, Thanks for getting back at me. I think the Sieg would be too little of a change but I do like the look at the Chester Craftsman. I should have said I'm open to both new and used (my CL300M was used). Cheers, Chris. |
29/09/2023 21:17:34 |
Hi, I was hoping the forum could help me choose a new lathe! I have owned a Clarke CL300M Mini Lathe for about 10 years and it has done well. For a while now I have been aware of its limitations from the workable area to the hassle of trying to part a piece and I feel its time to upgrade, the only thing is where to go..? I definitely want a larger chuck and spindle bore along with a really sturdy machine so that it doesn't vibrate when performing such operations as parting off (making this on a mini lathe more hassle than it's worth). I'm also looking forward to a bigger toll post! I've been looking at the Amadeal machines (AMABL210D) but am completely open to all and any suggestions. I realise I'll need to buy new tooling etc. and I'm not fused by this. Budget isn't really an issue either. Thanks in advance for your help!
Thread: Beginners First Mill |
22/08/2023 22:51:55 |
Posted by David George 1 on 22/08/2023 22:32:58:
I have the 16VS mill and it does most things i need but i found the Z axis handwheel at the back of the colum a bit of a nuisance with me being a bit short of stature, and had to do a mod to change the handwheel with bevel gears to the right hand side. I would sugest the 20VS which is slightly bigger. David Hi David Thanks for the recommendation. Cheers, Chris. |
22/08/2023 21:24:00 |
Posted by Vic on 22/08/2023 17:55:38:
Used VMC on here. Thanks Vic, Chris. |
22/08/2023 21:23:20 |
Posted by SillyOldDuffer on 22/08/2023 13:24:06:
Is 600 - 800mm square the maximum available, or is the table allowed to overhang? My WM18:
So a WM18 would nearly fit in the space, except the table overhangs by 275mm both sides, much more when the table is traversed. On one side my table projects across a walkway, ion the other it overhangs an area used for storage. The WM16 and WM14 are much the same design scaled down Can anyone provide their Max Right-Left table movements? It was size that decided the machine I bought: a WM18 was the biggest I could fit in. Dave Thanks Dave for taking the time to list the dimensions of your machine. I am quite flexible on space and this sounds doable so will check it out. Many thanks, Chris. |
22/08/2023 21:21:43 |
Posted by Vic on 22/08/2023 12:22:14:
Posted by Robin on 22/08/2023 11:02:09:
Has anyone ever played with a Deckel? Might you trade some of that American Bridgeport solidity for a bit of Continental, double-jointed flexibility? When Gotteswinter starts twisting his Deckel horizontal table through all its' degrees of freedom I go a bit slack-jawed and drooly I used an Alexander Master Toolmaker at work which is similar? Lovely little mill and very versatile. I’ve never been that impressed with the Bridgeport apart from the fact some have long tables which can be very useful. I’ve seen a number of old European Universal Mills that I’d far sooner have than a Bridgeport if I had the space and money. Thanks Vic, I'll take a look at it! Cheers, Chris. |
22/08/2023 21:20:32 |
Posted by JasonB on 22/08/2023 11:37:49:
If somebody wants to compile a what mill and what lathe guide then I'm sure Neil will happily post it as an article or make it a sticky in a suitable forum topic. Would probably need two of each, one to cater for those wanting a new machine and another for those with a liking for old iron Hi Jason, For newcomers to milling, such as myself this sounds like a great idea! Cheers, Chris. |
22/08/2023 21:19:09 |
Has anyone ever played with a Deckel? Might you trade some of that American Bridgeport solidity for a bit of Continental, double-jointed flexibility? When Gotteswinter starts twisting his Deckel horizontal table through all its' degrees of freedom I go a bit slack-jawed and drooly Hi Robin, Thanks for your post, sounds interesting! Cheers, Chris. |
22/08/2023 21:16:22 |
Posted by Vic on 22/08/2023 10:47:04:
If you can get one to fit your space somehow I can thoroughly recommend a small knee mill. Something like a used Warco VMC perhaps? Other designs of small mills can be quite limiting sometimes, especially mill drills. Good luck with your quest. Hi Vic, Thanks for your recommendation, I'll check it out. Cheers, Chris. |
22/08/2023 21:15:39 |
Posted by Mike Hurley on 22/08/2023 10:24:45:
Posted by Paul Lousick on 22/08/2023 08:05:50:
Which Mill of which Lathe is one of the most asked questions for beginners. Selecting a mill or lathe appropriate for your needs is a difficult task for those starting out in machining and is an expensive exercise. Especially if the wrong equipment is chosen. There is a wealth of information on MEW but difficult to find for new members to the forum. Therefore, I would recommend that a special section for this be added to the site and a link to it be displayed on the home page so new members are advised of it. After reading this first, they could then ask for other information, without someone repeating what has already been posted.
Agreeing with what Paul says. The Website FAQS covers many standard items like this and the common question about adding photos to postings. However, there is a lot of material in the FAQs and may be difficult for newcomers to see the wood for the trees and doubt if many bother to venture far into the dark forest! Also, there does seem to be more of an attitude these days looking for instant answers to everything ( Google world I suppose), and I admit to being as guilty as others at times. However, members of the forum are generous in their time and effort to reply regardless, even though you see the same info repeated time and again. Just thinking out loud - would it not be possible for the web site team to configure things so that when a newbie joins they are directed to a 'checklist' of say the 10 most common questions, which they have to agree to? Before going more into the sort of idea that I have, it will be interesting just to get feedback on the concept - good or bad. If it is a possibility, I appreciate work would be required, but am confident that members would contribute, as I would be happy to regards Mike. Edited By Mike Hurley on 22/08/2023 10:39:53 Hi Mike, Thanks for your comments and from using other forums and helping other people out I completely agree with you. I appreciate all the replies I have received and they are starting to help me get an idea of what I should be looking for. Cheers, Chris. |
22/08/2023 21:13:17 |
Posted by Clive Foster on 22/08/2023 10:14:35:
Probably best to assume you won't get it right first time and pick up something used to play with. Decently affordable and reasonably close to what you think you need shouldn't be hard to fine given a bit of patience. Prices for used machines in acceptable condition tend to be quite stable so you shouldn't loose significant money. Think of it as paying for training. Nothing like experience to sort the wheat of what you actually want from the chaff of what you think you want. Without practical experience as a guide even the most careful pre-purchase consideration and analysis tends to become a case study in screwing up by the numbers. Even experienced folk with all the qualifications get it wrong. Not to mention that once you have got the beast what you actually end up doing is often way different to what you planned. Case in point I went from BCA to Bridgeport via a Chester Lux style, large square column bench mill. The big bench mill turned out to be classic screwing up by the numbers. Perfectly valid analysis. But, for me, unliveable with in real life. Nothing against the machines considerable capabilities, purely wrong style of machine for what I ended up doing. Full scale, not model. Beginning with the assumption that first purchase is "starter mill" and being willing to change as soon as you outgrow it is great protection against the sunk cost trap. "Spent a fortune on this so I'm darn well gonna make it work." A great time sink that rarely ends well. Having decided before purchase that you expect to change it makes something to quite to specification much more acceptable too. Clive Hi Clive, Thanks for your comments and sharing your experiences. Cheers, Chris. |
22/08/2023 21:10:53 |
Posted by Journeyman on 22/08/2023 10:00:01:
Chris, have a look at my web page on milling machines it might help a bit! John Hi John, Thanks for the link, I will definitely take a look at this later! Cheers, Chris. |
22/08/2023 21:09:40 |
Posted by Howard Lewis on 22/08/2023 08:25:03:
The machine that you select will be determined by several factors. Space; Budget; and the use to which it will be put. The budget does need to allow for purchase of things like a good vice, possibly other clamping equipment, tooling, (Cutters, Collet chuck & collets? ) possibly extra measuring equipment, and if you have any ideass of gear cutting, a Dividing Head or Rotary Table, with a matching Tailstock. Where space is limited, it is not unknown for a milling machine to be placed across a corner of the workshop, so that the table effectively becomes the hypotenuse of a triangle. In my case the final determining factor was Height.. To save space, on one end, the table handwheel has no handle. Howard Hi Howard, Thanks for your comments, all good advice! Cheers, Chris. |
22/08/2023 21:04:15 |
Posted by JasonB on 22/08/2023 08:20:44:
A lot will depend of your 600-800mm space. If there is some clear bench space either side of that then you will get away with the table travel which often adds 50% to the stated width of the benchtop mills. If that is the case then you could get an SX3 size machine in there. If you are tight up against a wall or other tall items then you are going to be quite limited to X1 size machines or an X2 size would do most of the work and removing the knob on the handwheel when longer travel is needed may just allow you to make use of it's full travel if you don't mind the odd scraped knuckle. Edited By JasonB on 22/08/2023 08:20:53 Hi Jason, thanks for your comments. My space dimensions are very rough and I have allowed for the travel either side of the machine. Cheers, Chris. |
22/08/2023 20:58:21 |
Posted by Ramon Wilson on 22/08/2023 08:07:50:
If you can increase that space available Chris I have a very good Amadeal R8 taper RV30 mill and lots of kit for around your budget. See the for sales section for details and take a look in my album for images I have done little to sell this so far save mention and advertise it on here but have now re arranged my workshop and mill is the next to go. PM me if you are interested and we can talk things over Best - Tug Hi Tug, Thanks for your reply, I'll take a look at your listing later. My dimensions were very rough and I have a lot of play in all dimensions. Cheers, Chris. |
22/08/2023 20:57:10 |
Which Mill of which Lathe is one of the most asked questions for beginners. Selecting a mill or lathe appropriate for your needs is a difficult task for those starting out in machining and is an expensive exercise. Especially if the wrong equipment is chosen. There is a wealth of information on MEW but difficult to find for new members to the forum. Therefore, I would recommend that a special section for this be added to the site and a link to it be displayed on the home page so new members are advised of it. After reading this first, they could then ask for other information, without someone repeating what has already been posted. Edited By Paul Lousick on 22/08/2023 08:06:13 Thanks Paul, this sounds like a good idea! |
