Here is a list of all the postings eric fritz has made in our forums. Click on a thread name to jump to the thread.
Thread: Hobbymat tumbler gear instructions |
16/08/2023 22:52:51 |
Yes, thank you so much.
Sent you a PM with my Email addy.
12/08/2023 19:51:15 |
Posted by Phil Pemberton on 08/08/2023 16:57:02:
Sadly I haven't got a drawing but I do have the (unfitted) tumbler mechanism and could take measurements or scans if that'd help. My measuring instruments are limited - I have a micrometer, a set of digital calipers, a Mitutoyo DTI and the usual rulers and so on. No fancy kit like surface plates, sadly. What I'd really like is a copy of the bits of the instructions which I'm missing - notably the gear ratios. But I expect someone smarter than I could sit down with the drawings, leadscrew pitch (I imagine someone knows that) and scans and figure things out. If you take a look at the 2 photos I uploaded to my album, they have the two pages of the gear ratios which I have, there's another half-page of additional gear ratios I'm missing.
Of course what I really should do is put all the stuff I posted to the Hobbymat mailing list on my website - that includes a really nice cleaned-up PDF scan of the lathe manual which is very easy to read when blown up to A4 size! Edited By Phil Pemberton on 08/08/2023 16:58:05 Phil, have you had any time for this yet? I sent you and some others in the thread a PM about this.
Basic measurements for the layout would be very helpful even if not perfect, I could refine them from there and share with the group once I have it working on my machine.
Overall length, width, thickness, the pivot hole location and the pin boss locations for the gears along with the gear rack pivot location would suffice. |
07/08/2023 21:22:44 |
Posted by Martin Connelly on 06/08/2023 17:41:46:
For the purposes of threading what the tumbler gears do is effectively make it easy to add an extra idler gear in to the gear train then revert to normal RH threading afterwards. Unless you are going to be doing a lot of LH threading then reverting to RH a modification that allows you to add an idler gear into the gear train, when the odd occasion requires it, would be a simple solution. If you are planning to do a lot of feeding outwards when facing or towards the tailstock when surfacing this may be all that is required. Martin C Im a toolmaker by trade and would enjoy the added versatility this mod would offer. Im trying to make this small lathe as capable and easy to use as the full size machines I use regularly.
Having a gear to add or remove is not what I would prefer, Although that would be the "Simplest" thing to do, from a usability standpoint this would get tiresome.
Thanks for the input though.
06/08/2023 16:36:43 |
Hello all.
I have joined this site with intrest in the topic of this thread, the reversing tumbler gear attachment.
There are several people who would like to duplicate this for their latyhe but lack drawings to do so.
Would anyone be willing to provide detailed drawings/measurements for us to do so?
Thanks in advance. |
