Here is a list of all the postings Annalise Rees has made in our forums. Click on a thread name to jump to the thread.
Thread: Centrifugal switch replacement |
25/07/2023 21:38:18 |
Appreciate everyone’s help! |
23/07/2023 22:48:26 |
It may be beyond me to fix!?
23/07/2023 08:13:38 |
Can someone please help me - I am trying to fix a Newman Elf motor, specifically, replacing the centrifugal switch. I am trying to remove the cast collar section of the old switch off the shaft so I can slide on the new switch. I’ve tried to take off the bit that holds the belt by unscrewing the locking nut but still can’t get it to slide off? Maybe just stuck from years of grease and grot? I have given it a good spray with WD-40 hoping this might loosen it but still not budging. I’d much rather fix this than throwing it away as the rest of the motor is fine, and probably a whole lot better made than motors today. If anyone can help by giving a step by step instruction that would be appreciated as I can’t find anything online that shows or explains this. |
