Here is a list of all the postings David Lloyd 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Smart and Brown Model L. |
17/07/2023 20:25:49 |
I contacted Bracehand about a manual and asked if it explain how to remove the spindle. I got a reply asking to phone the factory and could I send some photos of the front and rear of the pulley assembly. I should get round to that this week. I also had a look on the Smart and Brown group. There is a mountain of information there, a lot of it about removing spindles but, I haven't found anything about the Model L in that regard. Thanks |
14/07/2023 22:06:36 |
Yes, the spindle I have is different to the one in the drawing. I tried to contact Bracehand by email as they say on their website that a parts manual is available, but I have not received a reply. Are they still in business? The lathes website has what they say is comprehensive manuals, and I wouldn't mind buying that if it would explain how to remove the spindle. Anyone had any experience of the sort of information contained in them? Thanks David Lloyd
13/07/2023 20:15:11 |
OK, thanks. This is what how far I have got. There is a collar on the left side of the spindle held by two grub screw. Unscrewed that. Next there is a flat plate held by eight allen bolts which I removed and can see the rear roller bearing. Loosened the grub screws on the pulley assembly. The pulley assembly will then slide to the right about 3/4". If I push the spindle to the right, it will move till the main rear bearing re-contacts the pulley assembly and then it's solid. It seems as though the rear bearing is fixed to the spindle in some way, but I can't see anything. I'm baffled, to be honest.
David Lloyd
12/07/2023 20:55:57 |
Thanks for the help. It has a plain bronze bearing at the nose and roller bearings at the other end.
David Lloyd |
12/07/2023 07:38:47 |
Good Morning, I'm hoping someone would be good enough to give me some advice. I was given this lathe some years ago and, I have finally got round to trying to make some use of it. Would anyone know how to remove the headstock spindle and maybe know what size the rear bearings are? I have tried to remove it, and it will only move about 3/4” forwards. Do the rear bearings have to be pressed off the spindle with some sort of special tool? Thanks David Lloyd
