Here is a list of all the postings Margaret Trelawny has made in our forums. Click on a thread name to jump to the thread.
Thread: Damaged Screws & QCTP help!!! |
31/07/2023 11:15:57 |
Hello chaps, sorry for my late responses but I am at work. I am awaiting responses from arceuro and Amadeal. Jason - putting the tool in and offering up to a workpiece looks fine - although I did have to adjust the tool holder up a little (not sure if this is normal practice as i have nothing to compare against) - but a standard tool of the size I generally use does reach the work piece ok. See pic. I will try the stud later when home tonight but it looks likely that the stud will work or worst case, I need a new stud. The threads on the original stud look a bit worn don’t they?
i’ll send dimensions of the stud later when home and reply to all the pm’s.
thanks all M
Edited By JasonB on 31/07/2023 11:26:56 |
30/07/2023 21:00:06 |
Jason:
30/07/2023 20:37:47 |
Not done it yet - I will be returning the ‘easy outs’ 👍😉 |
30/07/2023 20:15:10 |
Jason do these photos help at all?
Edited By JasonB on 30/07/2023 20:46:37 |
30/07/2023 20:12:51 |
Howard replied to your dm’s. Thank you. Jason, I’ll check the measurements you suggested tomorrow.
Thanks |
Thread: Quick change tool post and ball cutting |
30/07/2023 20:09:16 |
Hi Jason, sorry, posted in wrong thread! The forum jumps around on my phone when trying to load pics! I will reply on there tonkeep things consistent. |
30/07/2023 19:37:48 |
Hi Howard, sorry been out most of the day, just replied to your dm’s.
all the best Margaret |
30/07/2023 19:20:26 |
ok so have tried to put together my top slide (bearing in mind parts are out of action because of the broken screws) but the old tool post and the new tool post - to the bottom of the tool holder part - look about the same. Apologies for the scale drooping on the second photo - I didn’t notice when I took the photo - it seems to be about the same distance from the lathe bed. |
30/07/2023 11:55:35 |
Sorry about the higgledy piggledy post above - adding photos on a phone is tricky! |
30/07/2023 11:54:31 |
Thanks gentlemen. I have just purchased Jason - I am not sure the original stud is long enough? I tried to photograph it against the QCTP but the phone camera distorts it somehwat. The stud collar is aligned with the base of the QCTP in the pics and to me, looks about 15mm too short? |
30/07/2023 00:12:45 |
Thanks Neil and Bill for your input. I am pleased to say we got the damaged screws out! As suggested, starting with a 2mm drill, worked all the way up in .5mm increments carefully until we were able to gently wind a 5mm tap into the holes which split the remainder of the cores and they wound out. Yey! Now, should I replace them with cross heads or torx? Stainless? Appreciate you all and your generosity in helping. … now to sort out that pesky stud…. Not sure the arc one is correct as you say Neil. Will speak to both arc and Amadeal Monday and see if anyone can help.
29/07/2023 22:14:35 |
Hello Duncan - thanks for the link to Coventry Model Engineers. I will bear them in mind. I bought the 250-000 from arceurotrade - and although the post has been taken out of the bag, it hasn’t been used. Some oil has leaked off the parts onto the cardbord packaging - but I noticed the boxes for the holders already had oil stains on anyway. It seems though I have made another mistake in buying too small QCTP. Because the swing over is 12cm, I should have purchased a 250-111. So I am hoping to exchange it.
Malcolm - thanks will try your suggestions first.
29/07/2023 21:20:49 |
Thanks Mickb |
29/07/2023 21:15:52 |
Hi Howard, It has certainly given me a few grey hairs! |
29/07/2023 21:07:12 |
Hi Nick, You are right, I don't have the equipment nor the experience to attempt this kind of repair unfortunately. I will likely use the option Robert suggested above with the helicoil system. I don't know of any ME clubs around me, although I am sure there are some. Many thanks for your suggestions. All the best Margaret |
29/07/2023 21:05:21 |
ps: Robert, the M6 repair might be the better option because fortuitously, I found several matching bolts in a drawer which had come as spares with an Ikea kitchen. The are exactly the same and M6!
29/07/2023 20:56:02 |
Hi Robert Thank you for your suggestion - that is excellent. I didn't realise you could do that. If I can't get the screws out that is my next option. I appreciate it. Many thanks Margaret |
29/07/2023 20:51:26 |
Hi Howard, Thanks for your suggestions. I have definitely bitten off more than I can chew, and the disappointing part is that it all looked such a simple swap on the YouTube and ArcEuro videos I watched. Had I known what I was letting myself in for, I wouldn't have attempted it. I am near Coventry. Unfortunately, the shaft cap and larger diameter part of the original stud is larger than the newer threaded stud. Stud cap: 15.18mm Knurled part of stud shaft: 10.37 Fatter part of stud shaft: 10mm
New stud thread: 7.5mm All the best Margaret
29/07/2023 20:03:39 |
Hi all, No need for anyone to feel bad. It is part of my learning curve - proving to be costly and a headache but I guess that's how we learn.
Update: Everything is now apart - thanks Jason for your suggestion and input. I heated the ring a little and tapped it and again, it came apart. I just need to find a way now to get those damaged screws out - otherwise that part is scrap. For the toolpost stud, I just don't know what to do. I am not sufficiently experienced to make my own (as I am sure a lot of you guys are able to) nor do I have the tapping equipment etc. I have emailed both Amadeal and Arceuro to see if they can help. It seems the CJ0623b is slightly larger than a mini-lathe. I have nothing to compare so I don't know. It's such a headache. Thanks again for all your input and help, it is very much appreciated. Margaret
29/07/2023 18:04:14 |
Hi Noel, thanks for the reply. I took your advice and added a little heat and gave it a small tap and it popped out. Yey! But now I find the two posts are different! The one in the kit is threaded both ends - have I purchased the wrong kit from arceuro? The one on my lathe is a push in fit, the kit one threaded. (My lathe is an Amadeal CJ0623b if that helps?). The videos I watched on ebay it was a straight swap! Also, I have identified the little pin which seems to be stopping the circular part from moving. How can I remove this please? I am at my wits end! I wish I hadn't bothered and stuck with the 4-way tool post. Thanks all Margaret
