Member postings for Steam-Driver1
Here is a list of all the postings Steam-Driver1 has made in our forums. Click on a thread name to jump to the thread.
Thread: 3 1/2" Gauge Discussion Group
19/05/2023 06:39:39
Many thanks Phil for your reply,
i’ll check the valve clearances first before I do anything else & that’s a very good point about keeping the taper pins at 1/16 inch so they continue to act as shear pins in case of any further lock ups.
I’ll see if I can post some photos on here of the loco.
cheers, Dae
18/05/2023 08:11:45
I have just joined this forum as very keen on 3 1/2 inch steam locos, I inherited my Dads Henley 0-4-0 which I’ve had running a couple of times but having problems with the cylinders hydraulic locking with water & shearing the 1/16 inch steel taper pins that connect the piston rods to the motion link rod. I wonder if 1/16 inch is a bit small? I can’t see any details for these on the original Reeves drawings? Has anyone else encountered these issues with a Henley?
I’m going to fit cylinder drain cocks to alleviate the hydraulic locking
