Here is a list of all the postings Paul Wirdnam has made in our forums. Click on a thread name to jump to the thread.
Thread: Can Anyone Identify Who Made This Old Tilting / Swivelling Machine Vice? |
13/09/2023 18:08:26 |
This vice came with a turret clock I rescued from a derelict house in Kent in 2020. For the last 3 years, it's looked rather sad and rusty on my garage floor but this afternoon, I stripped it down, cleaned it all up, and I find now that its rather a nice vice, but there is no makers name on it anywhere. Most parts have "32" stamped on them apart from the vice itself which has "12". Looks to be very well made and vice jaws are 3" in length. Any ideas who made it? |
Thread: Warco WM250V : Tray Cleaning Questions |
22/08/2023 12:43:47 |
I bought this 1/2" BSP coupler from my local hardware store today.....it fits perfectly. Thanks for all your help. |
21/08/2023 14:12:10 |
Posted by Mick B1 on 21/08/2023 13:55:49:
Duh! I never thought of a tray! I use an old wooden ruler to scrape the swarf to where I can get it into a dustpan. I can screw an M20 x 1.5 thread several turns into the tray drain on my WM250V. If it was anything different I don't think I could do that. Thanks for the thread size. Do you use the drain? I also have a tray at the headstock end of the bed, but brass goes everywhere! |
21/08/2023 13:16:50 |
My previous 1940's Sheldon had a removeable steel tray between the two sets of feet and the tray caught 99% of the swarf and chippings, so cleaning was easy. The Warco sits in a tray and is bolted down through it. If I was only cutting mild steel then I'd use a magnet, but stainless steel and brass in particular are a right pain to clean up. So my questions are: 1) The tray does have a drain at the back with a course gauze as part of it. Underneath there is a flange with an internal threat. Does any one know what thread this is please? 2) If I can attach a hose to the thread in 1), what fluid should I use to wash down the lathe and tray? 3) Any other tips for cleaning up sharp swarf without wrecking the paintwork? Many thanks for any tips... |
Thread: Is this a Warco / Metric thing...or am I just out of date? |
18/04/2023 19:32:49 |
Posted by Ballistol on 18/04/2023 19:28:35:
As if my brains weren’t scrambled already, my Warco is set up for metric and imperial.
Very interesting! Which Warco lathe is that? Is that something you did or does it come as standard on the bigger models? |
18/04/2023 17:11:10 |
I would prefer it to be a radius dial because that's what I'm used to but I can live with it as-is. If I was using a milling attachment, then it would be awful.... Thanks for all your comments. |
18/04/2023 15:55:47 |
Posted by Bo'sun on 18/04/2023 15:38:51:
What I am struggling with though, is the 0.04mm graduations.
Absolutely! It's crazy, isn't it? I'm ok with 0.4 and 0.8 which are marked and I can just about find 0.6, but 0.65 would challenge me. |
18/04/2023 15:52:12 |
Posted by Dave Halford on 18/04/2023 15:37:17:
China's biggest market is the US, they don't do the two times table. And yet my 80 year old Sheldon was a Chicago made lathe.... |
18/04/2023 15:16:53 |
Finally got to do some serious turning on my new WM250V...but have been scratching my head why I can't seem to take the right size cut. Never had this problem during the 40 years of using my old imperial Sheldon.... At first I thought it was my unfamiliarity with metric units and me constantly looking up imperial equivalents in my Zeuss book. Finally dug out my imperial dial gauge and took some measurements as I wound the cross feed table in and out. So when did the cross feed dial indicator change to show total reduction of diameter rather than amount of movement of the table??? On my old lathe, if I wound the table in by 20 units on the dial, it would move in by 20 thou of an inch and take 40 thou off a diameter. With my Warco, if I wind the cross feed in by 0.8mm on the dial, it actually takes 0.8mm off the diameter. i.e table only moves in by 0.4mm (or 16 thou inch on my imperial dial gauge in the photo) I appreciate the latter set-up is more useful. But when did this convention change? Of maybe there is no standard at all... |
Thread: Imperial Thread Cutting on a Metric Warco WM250V : Some Questions |
16/04/2023 07:54:35 |
Posted by Mick B1 on 15/04/2023 14:49:58:
I have generally a pretty high opinion of the 250V. It doesn't have the power of the industrial lathes I used for my daily bread in the 70s, but OTOH that's also saved me a few broken tools. It's quiet, smooth, versatile and reliable - the only problems I've had have been of my own making, and fixable. Thank you for the links to off-table pitch gear calculation routines - I haven't come across requirements to do any such yet, but of course it's possible I may. Thanks Mick....that's good to know about the 250V. I loved my 80 year old 10" Sheldon but it lacked many features that a modern lathe has like electronic speed control, reverse motor, power cross feed. I put the following table together using data from the bilar website link posted above, so I'm not responsible for the calculations but having checked a few of them with other software programs that do these calculations, they match. I'll be using this table rather than anything in the manual or on the front of the lathe. I have it as a PDF but couldn't find a way of posting a PDF file on this Forum |
15/04/2023 14:01:12 |
Thanks for the reply Brian. It has a 2mm pitch. |
15/04/2023 07:54:50 |
A quick intro : for the last 40 years, I've been using my WW2 Lend-Lease Sheldon (Chicago) 10" lathe to restore pre-war British motorcycles. A couple of weeks ago, I bought a new metric WM250V and sold the Sheldon to a friend. Time will tell whether I'll regret this...... Got a few questions on the WM250V if that's ok? BTW: I've already read many of the excellent threads on this subject and have downloaded NthreadsP and PICCLOCK's "WM250 Change Gear Calculator" but my favourite is this online tool, **LINK** 2) Second question concerns the engagement of the horizontal leadscrew. The 250V introduced power cross feed but this level can also engage the horizontal feed but at half the speed (I think) to the main lever. Is there any reason why I should not use this new lever for thread cutting? If not, it means I can set up the change gears (for example) for 20tpi on the A (1:1) leadscrew gearbox setting and cover 10tpi on B (2:1), 40tpi on C (0.5:1) and then 80tpi if I use this new lever for leadscrew engagement? 3) I have no idea how to use the thread dial indicator when cutting imperial threads on a metric lathe...can anyone advise please? In the meantime, I'll play safe and not disengage the leadscrew.... 4) Why does the leadscrew have a groove running down its length? Man thanks for your help and advise |
