Here is a list of all the postings Paul Mercer has made in our forums. Click on a thread name to jump to the thread.
Thread: AMA 250Vx750 fault |
19/02/2023 16:00:11 |
Gents. I have a working lathe! I bit the bullet and purchased a replacement motor. I stayed with the same DC motor for ease! Thank you for all of your help and advice. It was really appreciated. Paul |
15/02/2023 20:45:18 |
So I did some more investigation. I took the motor apart to see what if anything the new brushes had done to the newly cleaned up commutator There were two distinct areas of burning on the commutator, with only 3 bars between them First I did the “180 degree test”, I measured the resistance of the windings on commutator bars 180 degrees apart. Secondly I did the bar-to-bar test, which measures each individual loop. The two individual loops around the burning, coincided with the 53K ohm readings. With these more detailed measurements, I’m guessing that it’s a new motor needed. |
15/02/2023 16:55:04 |
Good afternoon all. back home now for a couple of days, and found a set of brushes on the doorstep. I’ve just read through the previous comments and noticed a couple of typos - apologies, but I use my phone more than my laptop. I checked every wire in the lathe and did find that an earth to the chassis was loose, so tightened that. Hopefully that explains the shock. Starting up the lathe with new brushes and she blew the breaker again. Stripped it down and started it with the motor separate to the lathe, and it worked. Fitted the motor and it still worked. Added all the panels and it still worked. Put on the drive belt and it blew the breaker again. There doesn’t appear to be any excessive physical resistance when turning the lathe by hand. Why isn’t anything easy! Does anyone have any further thoughts? Thanks. Edited By Paul Mercer on 15/02/2023 16:55:32 |
11/02/2023 22:07:02 |
I’ve been away for a few days so don’t now work on the lathe. I stripped the motor down and had another look at the commutator. The gaps on the commutator had a lot of dark residue built up, presumably carbon, and the copper edges seemed slightly burred over closing the gaps down at the surface. I gave the commutator surface a cleanup with a bit of fine emery and removed the burrs abs dark residue. I checked the resistance and there appeared to be no shorts between any prt of the commutator. I put the motor together and using the old brushes checked resistance. No shorts between wires and housing which was good. I’m wondering if when I checked resistance before, I checked continuity between the housing and the wires?? I’ve spoke to the lathe producer and ordered another set of bushes. I’ll fit them when I’m home midweek, and give you an update. |
03/02/2023 21:50:17 |
All electrical testing was done with the motor removed and disconnected. I’ll double check the resistance between the wires and the casing when I’m home from work tomorrow. I’m based in Orpington, SE London/Kent borders. Thanks |
03/02/2023 17:00:10 |
Here’s an update.
I think I’ve (you’ve) narrowed the issue down to the motor. I couldn’t get and fast evaporating degreaser so that would be one last affront before I take the motor somewhere to be looked at. Does that sound about right? |
03/02/2023 12:36:58 |
Thank you for the replies. I didn’t notice any swarf or loose wires, but will check again. The shock came from the frame of the lathe itself - although all circuit boards were loose at the time, all earth cables were in situ. I wasn’t touching any electrical items at the time. I’m ok ’ish’ with electrics, but don’t know much about motors or controllers. This is clearly beyond my knowledge though! I don’t have an airline but will get hold of one of those pressurised air cans and give that a go. I’ll also get hold of some fast evaporating degreaser and give that a go. Thanks for the advice, I’ll keep you updated on progress. |
02/02/2023 23:30:06 |
Hello. After my lathe developed a fault earlier on today, I spent a few hours here reading some advice given to another member with a similar lathe issue. I’ve had my lathe from new, about 15 years, and it gets light/medium use. Today, I was using it quite happily, and turned it off. When I restarted it, it tried to turn for a fraction of a second, then stopped and blew the circuit breaker. I reset the circuit breaker and upon trying to start it, the same thing happened. At that point to took to the internet, and this forum. I thought it may be a Start Capacitor, so started to strip the lathe to find some specs for it. I was expecting to find a large capacitor near the motor, but found nothing, so presume it’s not that. I found 2 circuit boards: The second is an unknown circuit board. It has JD-013 REV B 070813 on it, and under that B43688. Research shows a similar lathe made by Grizzly who kindly have a similar part number and call this circuit board a Filter. I don’t smell any burning on the circuit boards at all. When I took the lathe apart, I closed the safety switches and tried to turn it on. The motor didn’t turn, but did make a buzzing noise, and the main chassis gave me a small shock. Figured that I’d mention that in case it made a different to anyone’s thoughts Does anyone have any advice how I could start to find out how to repair this lathe? Thanks in advance |
