Here is a list of all the postings James Mackay has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarke CL300 Blowing Fuses |
23/11/2022 14:42:06 |
Happy to report lathe up and running again with new board. Thanks All. Regards, James
20/11/2022 23:11:45 |
That’s the part I have ordered, certainly looks identical in the image. Will report back if I have any issues. Cheers! James
20/11/2022 14:51:09 |
John, many thanks for the valued advice. I'll purchase a new board.
Regards James
20/11/2022 13:36:20 |
Should I just replace the board, or is there any scope for repairing it? Any advice is welcome.
Regards James
19/11/2022 12:00:25 |
Ok, measuring between pins 4 and 7: About 13.0 settling down (about 5 seconds) to 00.5 Ohms in both directions. (DVM set to "200" Ohms setting)
19/11/2022 11:29:42 |
Hi John, Many thanks for the quick feedback. I have checked (nothing else connected): Pins 5 and 3 - is open circuit Pins 6 and 7 - is open circuit Pins 6 and 4 is also open circuit I have closed circuit between: Pins 4 and 5 Pins 4 and 7 and Pins 5 and 7
James |
19/11/2022 09:03:12 |
Hello, I’m new to this forum and hope someone can offer advice on an issue I have with my Clarke CL300 lathe. The circuit fuse always blows when mains power is switched on. I have check everything and replaced the speed control switch/potentiometer, but the issue is still present. I have traced a problem with the old FC250 control board in that there seems to be a short between connection “AC4”(live) and connection “5” (this is when nothing else is connected to the board. Is this something that I can fix (replace relay?) or do I need to order a new board from Arceurotrade? Any advice welcome. Regards James |
